05-24-2022 01:13 PM
Hi all.
I have two nest audios set up as a pair. Today for no reason at one has stopped working completely.
I have unplugged it etc however there is no response, no lights coming , nothing.
The other speaker in the pair works fine.
Just hoping someone has tips on what to do.
Cheers
Paul
05-24-2022 08:23 PM
Hey jkdpaul,
Sorry to hear about your Google Nest Audio, but thanks for bringing this up. A few questions: Is it plugged directly into a wall outlet or surge protector? When the speaker is plugged into the wall outlet, does it show any LED lights that indicate that it has power? Are other devices able to receive power from the same outlet? Are you using the official power adapter that came with the speaker? Have you tried another outlet? Also, was there any type of electrical outage around the time the issue began?
Please try these steps below:
Let me know how it goes.
Muddi
05-24-2022 10:06 PM
Thank you for your help. I have done all the steps and nothing changes. The power cable is fine , I tried it on both speakers and the other one works. It's very odd as nothing has happened, was not dropped etc just stopped working.
05-25-2022 04:28 PM
Hey jkdpaul and Karinakomkov,
Thanks for trying those steps. Just an added question: when and where did you purchase the device? Also, please let us know the country where you are located now.
Muddi
05-25-2022 11:04 PM
Hi.
I'm in the UK. I brought mine from the retailer Currys. I brought them in the 12 November 2020.
Paul.
05-26-2022 12:04 AM
Hey jkdpaul,
Thanks for the quick response. We'd be happy to take a look into this for you. Please fill out this form with all the needed information then let me know once done.
Muddi
05-26-2022 12:59 AM
That's done. Thank you
05-24-2022 10:47 PM
I have same issue, also teo6speakers one suddenly stop working and I did all steps you said
05-26-2022 04:01 PM
Hey jkdpaul,
Thanks for the update. We got the form you've submitted. We'll be reaching out to you via email and let's continue working on your concern through that channel.
@Karinakomkov: Have you fill out the form?
Muddi
05-28-2022 03:26 PM
Yes, I just filled the form now hope to find solution for my issue, thank you
05-30-2022 12:26 PM
Hi Karinakomkov,
Thanks for responding.
I've seen that you have been assisted by one of our support specialist. I'll go ahead and lock this thread and let's continue working on that channel so we can assist you futher.
Princess
