08-04-2023 02:01 PM
Have tried all the recommendations for getting the camera to work with no success. Camera used to work fine up until a few months ago. I was able to get it working again but shortly after it has stopped working. Maybe camera is bad but don’t know how to test.
08-08-2023 02:03 PM
Hi Lclewis,
This is not the experience we want you to have; let us help you. A few questions:
Also, kindly send us the firmware version of your Nest Hub Max. Follow the steps below:
To check the version on your Nest display:
Keep us posted.
Dan
08-11-2023 02:13 PM
I just wanted to follow up to see if you still need our help. Please let us know, as we would be happy to answer any questions you may have.
Juni
08-15-2023 01:35 PM
When trying to set up camera it asks me to scan qr which I do and then it goes into joining device for awhile then get something went wrong. I also am not able to set up the dish account as it also just says something went wrong. The dish integration used to work fine and then a couple weeks ago it stopped working. I de-installed dish but have not been able to reinstall. I have noticed that the home app has changed. Deviceinfo is
ystem firmware version: 11.20230306.3.135 Cast firmware: 1.69.362882 Language: en-US MAC address: 14:C1:4E:32:12:0B IP address: 192.168.0.212
08-18-2023 02:27 PM
Hi Lclewis,
Thanks for reaching out. What is the make and model of your router? How far is the router from your Google Nest Hub Max? Try to set it up in a new home structure and observe if it makes a difference. See the troubleshooting below:
Juni
