Nest home max keeps crashing
Hylkefaas
My speakers keeps crashing when playing some songs on high volume.
I have changed the power cable but nothing helps.
I previously had contact with your support and they said a future firmware update should fix the problem. But nothing has changed.
what can I do?
6 REPLIES 6
Juni
Hi Hylkefaas,
Thanks for posting. I’m sorry for the trouble this has caused you, let me help you out.
Could you please provide the existing case ID of your interaction from the support team so I can check it? Also, what is the firmware version installed on your Nest speaker?
Juni
Hylkefaas
Hello Juni,
case-ID [2-8819000032464]
The latest firmware is installed.
greetings Hylke
Juni
Thanks for the information, prior purchasing the new cord do you still have the original power cord? Have you also tried plugging it into another power outlet?
The reason why it reboots if it's in high volume is it's not getting enough power so if you don't use the original power cord anymore that might be the case. Check this link for the Nest speaker power cord specifications.
Juni
Hylkefaas
I still have the original cable and tried it on an other power outlet, but still the same problem.
Juni
Thanks for confirming and trying the suggested steps.
We'd be happy to take a look into this for you. Please fill out this form with all the needed information then let me know once done.
Juni
Azarco
Hello Hylkefaas,
We received your form — thanks for filling it out. Our team will reach out to you via email to further assist you. Also, please be advised that this thread will be locked after 24 hours.
Alex
