09-25-2022 12:26 PM
I have an issue with my nest hub max. For no apparent reason it stopped playing iTunes music requests (I had it linked and can play iTunes music on my phone fine) so I removed the nest hub max from my home config and performed a factory reset.
After joining the nest hub max to my Google home (android app) I was able to set it up but am still having problems playing apple music abd now I'm unable to complete the setup of the inbuilt nest cam.
I get an "error connecting to Google message".
I've tried uninstalling and reinstalling the home app, have removed the device from home and have performed about 3 factory resets so far to no avail, so I'm reaching out for advice.
thanks,
09-30-2022 04:27 AM
Same here, and google doesn't come up with a solution. I have my 2nd Nest hub max and the camera cannot be linked with the nest app. A month ago after a reboot, the camera can no longer be connected.
10-04-2022 09:05 AM
Thanks for reaching out.
We're sorry to hear about what you are experiencing right now with setting up your Google Nest Hub Max's camera. Let's go ahead and try these steps to see if you will still experience the same thing
If you attempt to set up the camera again:
Let us know if these steps work.
Princess
10-04-2022 06:02 PM
Hi Princess, thanks for your answer, but I already tried them all. Now I just checked the preview and rebooted and camera setup worked immediately, a lot of hassle to get this working and software bug on your side. I corresponded with Google Netherlands about 3 weeks ago to no avail. Anyway, I'm satisfied now. Kind regards
10-05-2022 12:08 PM
Hi albertocapo,
We appreciate all your efforts. We'd be happy to take a look into this for you. Please fill out this form with all the needed information then let me know once done.
Princess
10-08-2022 09:33 PM
Hey albertocapo,
Chiming in, have you had the chance to fill out the form? The form is only meant for you to use, so let us know once you’re done.
Muddi
10-09-2022 11:56 PM
Hi albertocapo,
Just bumping in to make sure that you've seen our responses. I'll be locking this thread if we won't hear back from you again in 24 hours. Feel free to create a new one if you have more questions or have other concerns in the future.
Muddi
