11-11-2021 01:41 PM
Hi everyone. So I bought a new Nest hub and set it up on my wife's home account no problem worked perfectly. I then decided to connect it to my account instead and performed a factory reset. It now will not connect to my router at all no matter what device I use to set it up. It says wifi password is incorrect no matter what I do. I have rebooted everything multiple times and nothing has worked so far. I have multiple speakers and a thermostat that I have reset and swapped accounts on over the years and they all are working perfectly. This 2nd gen hub is the only thing giving me trouble. Any ideas are welcome. Thanks
02-03-2022 10:26 AM
Hey Fredd32,
Sorry for the late reply. I wanted to follow up and ensure you are good to go. Please let me know if you are still having any trouble from here, as I would be happy to take a closer look and assist you further.
02-03-2022 10:32 AM
I had a replacement sent out and have had no issue with it. Only thing I can figure is a factory reset breaks something between my router and these nest hubs. I will make sure not to reset this one lol. Thx
04-21-2022 03:44 PM
Hey Fredd32,
We hope you were able to get the help you need but if you need assistance with your Nest Hub device, feel free to submit another post, and provide as many details as possible so that others can lend a hand.
Alex
