Nest mini won't connect to wifi.
pjclark1
I just had my router replaced, same name and password.
I have 2 google nest mini, 1 bedroom, 1 living room.
After router replacement neither would connect to internet.
Living room, went through setup, had to enter same password manually to connect.
Bedroom, same, can hear the 'connect sound' but doesn't connect.
Swapped nests ........ living room nest still works in bedroom. ...... bedroom nest won't connect in living room.
Just sits there saying "I can't connect to the wifi network ...... you might ........"
What do I do now?
pjclark1
Fixed it with a reset.
Turn mic off
Hold center of mini nest speaker for 15 seconds.
Various noises, but don't let go until sounds stop and 4 orange lights.
Wait a minute or two, google mini nest will suggest you setup using Google Home app.
Turn mic back on, Setup as normal.
All works.
55 REPLIES 55
pjclark1
during setup in google home
setup device
New device
(existing home)
Looking for device ......would you like to setup this device (yes)
Connecting to Mini Nest ....... connected ...... did you hear the sound (yes)
Improve ......... no
Where is device ....... Kitchen
Select my wifi
enter manually ..... connect
Could not connect with your nest mini (this is shown the INSTANT I hit connect)
The other mini nest (called 'living room') connects easily in any room, I can carry it around and plug in wherever.
pjclark1
Turn mic off
All works.
Reset the version hope you will
Muddi
Hey pjclark1,
Thanks for posting.
Happy to hear that your issue was resolved. Thanks to @maherazib for helping.  It looks like we can consider this one complete, so I will lock the thread shortly unless I can help out with anything else.
Muddi
Piotr-1977
Mam problem z Nest Mini, codziennie rozłącza się z wifi i aplikacją home, co robić ?
q11alpha53
Dear Muddi, I have become so frustrated trying to battle my risen "smart tv"to allow me the "privilege" of connecting my fire stick I have just about sworn off tech and returning to the worlds of classical music and literature .I have had a lifelong struggle with severe ADD,which only serves to make the nuances of Tech seem insurmountable. At this point I'm not even sure why I am writing this other than it allows for a readable"primal scream". At this point, I'm so overwhelmed I'm just going to end this pathetic diatribe and go to bed. Thanks for your unseen "support". It meant a lot.  Bob Kidder
Ktkoo
Hi i have the exact same problem.  I have changed net work provider, reset my 3 minis. None of them will connect. Ant suggestions? Thanks.
Happychap
Hi this worked for me
Turn mic off
hope this helps 😀
Muddi
I haven’t heard back, so I’ll be locking the thread in 24 hours. Thanks for posting!
Muddi
The reset did not help me on my Pixel 4 XL, I had to add it to Google Home on my husband's Samsung tablet. That worked fine.
Wykonuję to codziennie i ciągle się rozłącza zawsze między 11 a 12
Mine turns orange when I turn off the mic… still can’t connect
AO1
This google nest device was given to me from my daughter. Am I to erase her info? To get it started?
Laurice
where do you find how to setup on google hub, my doorbell does not ring on the hub and make announcement
Still won't connect despite many resets
Do you know if your router is broadcasting? Can other devices connect to your router with your password? If you know how, set your router to broadcast at 2.4 GHz. That seemed to work for me. I set it back to 5Ghz after setup with no issues.
Muddi
Due to inactivity, I'll go ahead and lock this thread in 24 hours. Feel free to start a new thread if you need assistance with your Google speakers and we'd be glad to assist you further.
Muddi
Consistency
polis
nao funcionou ja fiz todos os passos e nao reconhece nada.
fica a pensar e nao sai disso ate apagar as luz.
ja tentei na app e nao encontra o despositivo de som
Thank you so much for your help I have now reset Mini Nest
Keith
Stella1
I have the same problem and feel like throwing the nest against the wall. I've followed all the steps, to factory reset etc but I still can't get it to work. All because I had a new router.  The Google home app asks me if I would like to connect to the living room speaker but cant connect. Then tells me connection failed, try factory resetting, which I've done umpteen times now.
Muddi
Hey Stella1,
Sorry to hear that you're still having connectivity issues with your Nest Mini. To eliminate network issues, please try setting up your device using a mobile hotspot. Please note that you will need two mobile devices for this setup (one will serve as a router and the other to be used to set up your Google Nest Mini).
Let me know how it goes.
Muddi
Muddi
Hey Stella1,
I wanted to follow up and see if you are still in need of any help? Please let me know if you are still having any trouble from here, as I would be happy to take a closer look and assist you further.
Muddi
polis
segui todos os passos e nada ainda tentei com o nest e nada tambem ele so pisca as luzes e nada mais tentei devolver mas como nao tenho a factura nao aceitam de volta ou para fazer reparacao
Happychap
Hi Stella,
Turn off Microphone then place your fingers on the four lights for around 10 seconds, you should hear commands from your google nest. Open up your home google app and follows the instructions.
It worked for me, good luck
Keith
Darwin
Misschien is het handig om twee groepen te maken. 1-Woonkamer en 1-Slaapkamer. Zo heb ik het op gebouwd en het werkt super.
Muddi
Hey Lou3,
I just wanted to check if you still need help with your device? Feel free to respond and we're happy to assist you further.
@Darwin: Thanks for your input.
Muddi
RonnyP1
Mine does the same thing I cannot find solution anywhere
Muddi
Hey RonnyP1,
To confirm, are you able to try the steps above?
Muddi
Muddi
Hey RonnyP1,
Just bumping in to make sure that you saw our responses. Let us know if you still need help, and we're glad to assist you further.
Muddi
Muddi
Hey RonnyP1,
Muddi
Heo
Definitely need help to get mini back online and stay onli
Lou3
HUA00KTC  new router can’t update for isp connection
pls advise help
Muddi
Hey Lou3,
Thanks for the input. Have you tried resetting your device prior connecting it to the new router?  If yes, try setting up your device using a mobile hotspot. Please note that you will need two mobile devices for this setup (one will serve as a router and the other to be used to set up your Google Nest Mini). Once done, check if your device will have the same behavior.
Muddi
dsamvp
I’ve had the same problem and successfully connected to the hotspot but I still am unable to connect to the wifi even after factory reset. Any solutions?
Darwin
Hi Lou3,
Wat zijn de specs van de router? Weet je zeker dat hij  5mHz doorgeeft?
Azarco
Hey all,
Alex
dsamvp
I posted my question above but I’ve tried everything in connecting it to the wifi to no success however I’ve been able to connect it to a mobile hotspot. Any solutions?
Woppo_the_chook
Do a factory reset and start over
