No audio from nest cam on nest hub
Jsantosg
I am having the exact same issue as this user:
https://www.googlenestcommunity.com/t5/Speakers-and-Displays/no-audio-when-streaming-nestcam-on-Goog...
wr also use the nest cam as a baby monitor. I have a google nest hub and a nest hub max. Neither of them play the cam audio. It’s video only.
on the google home app I am able to see the video and hear the audio.
I have a 2nd gen wired camera.
Juni
Hi Jsantosg,
Thanks for reaching out — let’s see what’s going on.
A few questions: when did your issue begin? Is this working before? What’s the router that you are using? Also, what's the troubleshooting steps you’ve done so far?
Give these steps a try:
  1. Make sure they are on the same Wi-Fi Network.
  2. Reboot your Wi-Fi router.
  3. Reboot your Google Nest displays.
  4. Reboot your Nest Camera.
Let me know how it goes.
Juni
Jsantosg
I will follow you suggestions.
2-3 months ago
Yes
Don’t know.
Deleted the camera from the household and started from scratch with ut
Rebooted the googles nest hub max
Fun fact. The issue is with our google nest hub max. The google nest hub in a different room works just fine
Juni
Gotcha, If the issue is isolated to just the Nest Hub Max, Try a factory reset to put it back to its default settings and set it up one more time. Check the instructions below:
  1. Save any important footage from your device's video history.
  2. Remove your Nest Hub Max from the Google Home app Google Home app.
  3. On the back of Nest Hub Max, press and hold both volume buttons together for about 10 seconds. Your Nest Hub Max will let you know that it's resetting.
Keep me posted.
Juni
Juni
It's me again. I want to make sure you're all good — how did the steps go?
Juni
Juni
Hello there,
Just checking in to make sure that you saw our responses. I'll be locking this thread if we won't hear back from you again in 24 hrs. Should that happen, feel free to create a new one if you have more questions or have other concerns in the future.
Juni
