No audio from nest hub and nest mini
mrgee66
When I ask the google nest hub and the nest mini to play a radio station it says it's playing but there's no audio. I have done the factory reset and unplugged from power etc. The problem started when I changed to a new ISP. Both the hub and mini played the radio station previously without any problems.
Alex_S
Hi mrgee66,
I know how it feels when something isn’t working the way it should. Let’s further look into it. Is it happening to all stations you asked for? Can you play radio stations using Google Assistant on your phone? Do other streaming commands, like playing music, work? I’ll look forward to your response.
Alex
