07-24-2024 03:01 PM
My wifi needed to be rebooted so I am trying to reconnect my nest hub. I completed it and it says it connects but then it says something went wrong and I need to turn on local network access on my phone….but it is turned on….
I have gone through the trouble shooting list and nothing is working. What do I need to do?
07-27-2024 02:45 PM
Hello @Megs1883,
Thanks for posting in the community.
I understand the frustration of encountering difficulties reconnecting your Nest Hub after a reboot. The error message indicating the need to turn on local network access, even when it's already enabled, is indeed perplexing.
To give you the right steps, I need you to answer the questions below:
In the meantime, you can try these additional steps:
Please let me know how it goes. Thank you.
Jorge
07-27-2024 02:45 PM
Hello @Megs1883,
Jorge
07-29-2024 10:35 AM
Thank you. This worked well.
08-09-2024 09:55 AM
I realize this is a late notice however, some routers do not switch easily from 5G to 2.4G. It depends on the router brand. And rebooting the router is not conducent to being productive. As an IT SME when someone says reboot the router. Never ever. That is always the standard comment. My advice is to if it is on 2.4G, then change to 5. And sometimes, routers only allow an X amount of 2.4G devices on their channel. I have tons of wireless devices on 5G and tons of IOT devices on 2.4G. It would be a mess if I rebooted for everytime someone said reboot. It is not needed.
