Problem setting up google nest hub kgskerror domain 83902
Niniparis
I have a google nest hub 2nd generation. I don't manage to install it
I manage to connect it to wifi but when I reach the step "set up google assistant" I get the message "the operation couldn't be completed kgskerrordomain error - 83902
I've already been on the support community and tried all I could find. I reseted the wifi router, the nest hub....etc but nothing works
When resetting the nest hub though the language that appears at first is german, not sure why and i don't speak german. I am french but use all my devices in english (including google)
I have already spent at least 3 hours over several days trying to solve this. I must say it is super annoying and I am surprised that so many other persons seem also to have issue with a simple google device
Please help ..
the phone on which Google home app is is an iphone 15, up to date
Thanks a lot
19 REPLIES 19
@Niniparis
There have been numerous other posts about the kgsk error domain 83902 in the last few weeks.
Google Nest does not seem to have an explanation. On one post (https://www.googlenestcommunity.com/t5/Speakers-and-Displays/error-83902-kgsk-error-domain/m-p/55415...), a Google Nest Support Specialist posted this:
"To help the team further look into this, please send feedback using the Google Home app, followed by the keywords 'GHT3 KGSKErrorDomain error -83902.'"
ok will see if i manage, thank you!
Muddi
Hello everyone,
Thanks for reaching out. I appreciate @MplsCustomer's help here. Just to add to that, please try setting up your devices using a different account. If it's still the same, set up your device using a mobile hotspot. Please note that you will need two mobile devices for this setup (one to serve as a router and the other to be used to set up your Google Home/Nest speakers).
Let me know how it goes.
Muddi
Niniparis
Hello, I have only one google account and do not wish to create multiples account. I want to keep things simple 🙂 I am not sure what is a "mobile hotspot". Could you briefly explain? thanks a lot for your help
Juni
Hey Niniparis,
Thanks for the additional info you've shared. We'd be happy to take a look into this for you. Please fill out this Contact us form with all the needed information, then let me know once done.
Juni
Niniparis
Ok will do thank you because it is very frustrating
Alex_S
We haven’t seen your form submission come through—were you able to access it alright? Let us know if you’re running into trouble or still need our help.
Alex
Alex_S
Hi Niniparis,
We got your form—thanks for filling it out. Our team will reach out to you via email anytime soon. Please continue the conversation there so the team can further assist you. If you have other questions or concerns aside from this, let me know.
Warmly,
Alex
Truscheinsky
Hi
Have you figured out the problem.
I am having the same issue
Niniparis
no not figured out, waiting for answer from google
Niniparis
ok I will try and let you know
Niniparis
ok I looked and it doesn't help in my case. All my devices are in english already. when I start the google nest hub it shows up in german but i have no way to change it since i can't even finish the set up....Thank you anyway
dhindc
Sorry. It worked for me. Maybe switch your phone language to English UK, and then switch back to English US, and see if that helps.
Niniparis
ok i will try
Gabe86
On iOS it is unable to set up Google Nest Hubs, only if you set your phone or tablet language and region to the same you would like to use the Google device.
If you would like to set up English (UK) on Nest Hub, then your iPhone should be set to English and Region UK.
Restart your phone and then you can finish the setup.
Alex_S
Hi Gabe86,
Thanks for sharing this information. If you have questions or concerns on Google Home, let me know.
Alex
Lednek
Yea really sucks you spend this money and it not work out of the box, come on Google get you **bleep** together
Princesss
Hey Lednek,
Sorry about this experience. Some users have confirmed that they have fixed this issue. Let's try these steps and see how it goes.
  1. Change the default language to English US
  2. Change your Google Account to English US as well as your assistant's language.
Let me know if these steps work.
Lastly, thanks @MplsCustomer for chiming in.
Princess
