Radio starts and Nest announces also it will stop after a minute 🤨
realjax
Soooo, here's the next new weekly issues I have with the nest system.
When I play a particular radiostream (80s80s radio) and I use the EXACT right command (otherwise the hub has no clue what it is I want to play), the nest hub actiually starts playing the stream and says 'I'll play xx radio on xxdevice, xxx device will stop playing after 1 minute and 20 seconds'. And it wil stop.
What gives this time Google???
realjax
command to use is ( in dutch) 'speel eighties eighties radio op tune in' . ALL OTHER commands fail or will start a different radio stream.
Muddi
Hello realjax,
My apologies for the late response. You’re stuck in a tricky situation here, and I can feel how eager you are to resolve the issue. Let's try to get to the bottom of this.
A few questions:
  • When did the issue start?
  • Have you tried using the radio frequency to see if you will have the same issue?
  • Does the same thing happen when you use the Google Assistant app on your phone?
To isolate the issue, let's go ahead and try changing the device language on your Google Nest display. Let's see if you'll get the same response when your Nest Hub's language is set to EN_US. Follow the steps below to know-how:
  1. Open the Google Home app.
  2. Tap Settings > Google Assistant > Manage all settings > Langauges.
  3. Tap English (United States) or whatever language is currently selected.
    Note: By default, the language is set based on the customer's region.
  4. Choose the preferred language to use instead. It will immediately apply to the selection.
Let me know how it goes.
Muddi
realjax
Don't know, might have always been there
. Dont know what you mean here. 80s80s radio is a german based internet radio station. What is it exactly that you want me to do ?
No, works fine on my phone ( in Dutch)
" Follow the steps below to know-how:
  2. At the top-right, tap the Account icon.
  3. Tap Assistant settings > Languages.
  4. .....  "
Have you opened the app once over the last couple of months? Doubt it. But I strongly advise you to do so and then see if you maybe want to change your instruction set.
However when set to english US the command 'play 80's 80's radio on tunein' works fine.
Muddi
Hey realjax,
Sorry for the inconvenience. I've updated the steps in my previous posts so other users with the same issues will be able to change their assistant language properly.
Radio frequency is the alternative channel for radio stations like 93.8 or 98.3. One more thing that we can try is to create a routine using the "Add your own" action. Below are the steps on how to do that:
  2. Tap Automations > Add > Personal Routines.
  3. Under “How to start,” tap Add starter.
  4. Under “This Routine will,” tap Add action.
  5. Choose "Add your own," then type: Play 80s80s radio (In Dutch).
  6. Try using the routine to see if you will have the same issue when playing via routines.
Keep us posted.
Muddi
