Smart Display Wireless Headphones
noahdolieslager
I want to be able to connect my 3rd generation AirPods to my google nest hub 1st gen. I have tried doing it as a speaker, but it does not show up.
MrVacca
Silver Product Expert
Not sure that feature is available at this time.  You should ask for the feature request directly in the Home app.  Click on your profile icon in the top right corner and then you'll see the feedback option.
8 REPLIES 8
MrVacca
Muddi
Hey noahdolieslager,
Thanks for reaching out and apologize for the late response.
Appreciate your help MrVacca. Airpods and all other Bluetooth-enabled devices (headphones, speakers) are supported and can be paired via Bluetooth on the Google Home and Nest speakers or displays. Everything is done via the Google Home app on your phone.
Please follow the steps below to know-how:
  1. Open the Google Home app Google Home app.
  2. Make sure you're in the right home. The name of the home is at the top of the screen. To change homes, tap the arrow next to the home name.
  3. Tap your device.
  4. At the top right, tap Settings  and then Audio.
    • If this is your first time to use Bluetooth on this device, tap Paired Bluetooth devices and then Enable pairing mode and then go back to Audio.
  5. Tap Default music speaker and then Pair Bluetooth speaker. Your Google Nest or Home device will then scan for Bluetooth devices.
  6. Tap the Bluetooth device once it appears on the screen and then Done.
  7. Your Bluetooth device will now pair with your Google Nest or Home device.
For more information on how to play music on Bluetooth headphones, please visit this link: Play music on Bluetooth speakers or headphones
Let us know if you need further help.
Muddi
Ok, i try that, it doesnt appear
Hey all,
I wanted to check in and see if you managed to see Muddi's post? Are you still in need of any help with your device? Please let me know if you have any questions from here, so we can further assist.
Yes thanks
Muddi
My apologies for the delays. How's your device? Let us know if you still need help and the community will be glad to assist you.
Muddi
I wanted to follow up with you, and see if you had any questions from here. Please let me know, as I would be happy to take a closer look.
