Themed timers on Nest Hub Max stopped working again
craigbillings
Nest Hubs have themed timers with video and audio that match the type of timer set. e.g. if you set a "Tea" timer, the screen would display teacups and play the song "I'm a little teapot". Unfortunately, the audio portion stopped working. I really liked this feature. This same issue happened about a year and a half ago.  see https://www.googlenestcommunity.com/t5/Speakers-and-Displays/Themed-timers-on-Nest-Hub-Max-stopped-w...  Google was able to fix it then. Can they please do the same thing and fix it again?  Thanks!
7 REPLIES 7
AxelD
Hi craigbillings,
Thanks for posting in the Community! Sorry to hear that the theme timers stopped working at your Nest Hub. No worries, help is here! Let’s try performing some troubleshooting steps that might help you:
  • Remove the Nest Hub from the Google Home App
  • Perform a Factory Reset
  • Set up again in the App
Let me know how it goes.
Axel.
This did not solve the problem.
Kwinkelman
This has also happened to our device. Factory reset and add back to the app did not make any difference.
it is clearly the same sort of issue as the last one from 2023. It is disappointing that a company with the resources of google has repeated issues like this.
RebelKittenxRae
I am also having this same issue for several weeks now. I've factory reset my device and removed and re-added it to Google Home with no luck. Please bring back the themed timers! 😕
tkenn1s
This is a real shame. I loved the themed timers. Especially the chicken one. Hope Google can release an update to fix this.
Kwinkelman
These started working again in the last few days for me, yay!
craigbillings
Reporting that the themed timers are working again. Thanks!
