Use speaker pair with Nest Hub Max
Spiz
I own a the Nest Hub Max, along with two Nest Audio speakers (in a stereo pair). I have added the Hub and Pair to a group and have it set for my default for music group from the Hub. (Essentially using the hub as a center then a left and right) Which works great! But it only works for audio. I haven't found a way to use the pair with like YouTube videos or Netflix. Does anyone know how to do this, if it's possible?
If not I totally think it should be added as an option. I should be able to cast audio from a video to any Google home/Nest audio devices. Also are we ever gonna get the ability to add front and rear speakers? Just saying I have a pair of mini's that would work great for a pair of rear speakers.
Spiz
frances
Hello Spiz,
Thanks for reaching out! I would be more than happy to help answer your question.
Yes, you are correct, speaker groups only work with audio and music.
Thanks for your suggestion! If you'd like, you can send in feedback to our team regarding this feature request. Also, I do not have information or knowledge regarding front and rear speakers, so feel free to add that into your feedback to the team. Here are the steps to sending in feedback.
Thanks for your message and ideas!
GarrettDS
Have a great day.
Garrett DS
GarrettDS
Have a great day,
Garrett DS
