VLC no longer casting to Goggle Home Hub
babyl
VLC stops  casting music to nest hub max and nest hob 2° generation.
It has been working fine since a month ago and then stopped.
It still works with nest mini an the old google home
Thanks for the help
Juni
Hi babyl,
Thanks for reaching out and for the information you’ve shared. A few questions: what is the exact message you are getting when you stream it to your Nest displays? Were there any recent changes made before it started? Also, what steps have you taken so far?
Let’s try to refresh your devices and observe if it makes a difference. First, reboot your Wi-Fi router, and once the network is back up, do the same thing to your Google Nest Hub Max and Google Nest Hub (2nd gen) and your casting device.
Juni
babyl
Thank you for your kind reply.
I had already tried all these steps days ago but nothing worked.
Suddenly yesterday started to work correctly again!
I hope it doesn't stop again.
Thank you again for your help
Muddi
Hello babyl,
Perfect! We're happy to hear that you're able to cast VLC now on your Nest displays. Feel free to update the thread if you have additional questions or concerns about your Nest display, and the community will be happy to lend a hand.
Muddi
