When will Nest Hub Max fully migrate to Google Home App instead of using Nest App?
Lt_Battlefield
Hello, I'm a long time Google user of many Google Products. I remember reading in the past that Nest Products using the Nest App will be migrating over to Google Home App. So my question is.
When will all the features for Nest Hub Max be migrated over to the Google Home App that's available in the Nest App?
Example: Getting notifications of Camera noticed movement or noise from the microphone while I'm at work. These notifications should be coming from the Google Home App not Nest App. Can all the camera and microphone features be migrated to the Google Home App?
I prefer to just use one App. These are the only devices I have that use the Nest App.
Side note: Strange bug I found. When I get to work I get a notification about 1 hour after I'm at work that both of my Nest Hub Max cameras noticed some motion. It's always my home lights are turning off which should have all turned off shortly after I left based on my phones GPS.
JillG
Hi @Lt_Battlefield
I'm in the same boat. I have Protects and a mix of old cameras, hubs, doorbell and new cameras.
No information that I'm aware of but hoping that the Google Home app will become the "one stop shop" sometime and hopefully.
Jill
Lt_Battlefield
I forgot I also own Nest Protect (Smoke, carbon monoxide) detector. This device also needs to be fully migrated over to Google Home App.
JillG
Hi @Lt_Battlefield
Jill
JillG
and re: the bug
Are the lights turning on shortly after you leave the house or is the notification delayed about the 'movement'?
Andybrad
Adding myself to this list.
