my nest audio turn a light in his display
LuisLópez
sometimes, my nest audio turns on one of its four lights, to be more precise, the one on the left side looking at the horn from the front, what is it due to?
8 REPLIES 8
MikeClark2000
Google Nest Detect uses its light ring to let you know what's happening or if it needs your attention for things like a low battery. If you've turned Pathlight on, it will also light your way in the dark when you walk by.
Aiden1
Product Expert Alumni
It's the status light telling you you've got a notification from the Google app, most likely a reminder.  Try asking the speaker in question, "Hey Google, what's up?"  It should tell you what it's trying to notify you about and the light should then disappear.  I get these lights several times throughout the day due to reminders I've set in the Google app or in my Google calendar.
Dan_A
@MikeClark2000, @Aiden1, thanks for helping.
@LuisLópez, your Nest Audio reminds you that a notification is available. To hear the notification, say "Hey Google, what's up?" as stated above. For more information, see the links below about LED status and norifications.
Hope this helps.
Dan
Dan_A
Dan
LuisLópez
I had read something like that before, but I tell him and he answers like, I've been learning some jokes, something like that, the strange thing is that afterward it goes off
Muddi
Hey LuisLópez,
To confirm, how often does it happen?
Muddi
Juni
I'm jumping in to follow up if everything is good here. Let us know if you have any further questions.
Juni
Dan_A
Hi LuisLópez,
Dan
