nest audio werkt niet meer
Erwin50
Mijn Google nest audio regeert helemaal nergens meer op lijkt wel of er geen stoom meer binnen komt
Andere stekker geprobeerd van een andere speaker maar werkt ook niet
gmelanymelissa
Hi @Erwin50,
Thanks for posting here in the community. I'm sorry to hear your Google Nest Audio doesn't respond. Help's here!
To better understand the situation, I'd like to ask a few questions:
  • Is the Nest Audio powered on?
  • Does the Nest Audio show any LED lights that indicate that it has power?
  • Did you get an error message?
  • Is the official power adapter that came with the Nest Audio used on the device?
  • Was there any type of electrical outage around the time the inconvenience began?
Keep me posted.
Melany
Hi @gmelanymelissa
Thank you for your reaction,
           Is the Nest Audio powered on? Does not react on annything. completely dead.
  • Does the Nest Audio show any LED lights that indicate that it has power? No
  • Did you get an error message? No
  • Is the official power adapter that came with the Nest Audio used on the device? Yes, and i tried an other power adapter from my other nest who does work but also no response on this one.
  • Was there any type of electrical outage around the time the inconvenience began? No not that i know of.
I like to hear reaction, although i'm afraid that its game over with this Nest.
I had it for 2 years
Erwin
gmelanymelissa
Hi @Erwin50
Thanks for the follow-up information.
Please try the steps here:
  • Unplug the power adapter from the outlet and the Nest Audio.
  • Leave it unplugged for 20 seconds.
  • Plug the power adapter into the Nest Audio.
  • Plug the other end of the power adapter into a wall outlet that works.
  • Check if any LED lights would appear on the Nest Audio.
Melany
