10-17-2024 05:44 PM - edited 10-17-2024 05:50 PM
All of a sudden the remote control stopped working. I've tried resetting chromecast, but that doesn't help. Tried re-pairing the remote control. Have also tried app remote control on android, nothing works. I can't go into any settings to check the problem. The ony button that work is on/off. Is there a solution?
10-20-2024 05:55 PM - edited 10-20-2024 05:56 PM
Hello @Bjornajo,
Thanks for posting in the community. I apologize for any inconvenience you've experienced with your remote control.
I understand that is not responding, and it's just working when turning the volume up and down.
Let's try the next:
Let me know how this goes to keep working together and find a resolution.
Thank you,
Catheryn.
10-20-2024 09:00 PM
Thanks for your answer. I had to factory reset Chrokmecast Android TV. Very sad, because i had apps on it that is currently only available in my home country. But it work just fine after factory reset
Hello @Bjornajo,
Let's try the next:
Thank you,
Catheryn.
10-20-2024 09:00 PM
