Crome cast remote is not working
nithinpangl
Dear Team
My crome cast remote is not working now. I bought this 8 months before. When iam putting new battery🔋 the remote is heating up. Then I reset my crome cast device now I can't even use this in my tv. Can you please advise what should I do.
David_K
If you're happy the batteries are good (try them in another device to test), try these steps:
  1. Remove the batteries from the remote.
  2. Using your phone or other remote to navigate, go to Settings > Remotes & Accessories.
  3. Select your remote and choose to Forget it.
  4. Choose Pair remote accessory to start a new pairing.
  5. Hold the home button on the remote down and re-insert batteries while holding the button down.
  6. The remote should be detected on the right side of the screen. Use your alternate remote to select it to pair it.
JenniferV
Thanks for the help here, davidking.
nithinpangl, hope that helps, but if you're still having trouble with your Voice Remote, please replace all batteries at the same time. Do not mix old and new batteries and do not use lithium-ion or any other batteries with rated voltage above 1.5 V. Also, do a factory reset on your Voice Remote and Chromecast device, then observe the behavior.
Keep me posted.
Jennifer
JenniferV
Hello nithinpangl,
How's it going? Did those steps help? Still need help?
Jennifer
JenniferV
We haven't heard from you in a while so we’ll be locking this thread if there’s no update within 24 hours. If you're still experiencing problems, please feel free to start a new thread and we'll be happy to help.
Jennifer
