11-09-2024 09:04 PM
I bought a Chromecast but I faced several problems
The first problem is that it is not possible to lower and raise the volume in the remote and it is not possible to control the Google Assistant
The second problem I faced is that I cannot summarize the application store on the home screen
The third problem is that I cannot download applications outside the store, and there is no box in the settings that allows downloading applications from unknown sources
11-13-2024 03:47 PM
Hi Azooz6494,
Thanks for posting. I understand that you are facing some situations with your Chromecast device, such as not being able to control the volume, summarize the app store on the home screen, and download external apps from the app store. Don't worry, I can help.
For the first situation with the volume, you can try with these steps:
You can check the "Set up volume, power, and input control on your Chromecast or Google TV Streamer Voice Remote" article for detailed information.
For the concern about the store application on the home screen. In this case, you can just search for the apps on the apps tab; the store app is not going to show up on the home screen. You can check this:
Here are the apps that you have available on your Google TV. We do not recommend downloading apps that can be dangerous for the device's functionality.
Please let me know if you have more questions.
Jenny
