I'm using the OWN rule Chromecast player from Walmart the volume goes from low to extremely High
Grace
Googler
Googler
Disclaimer: This thread was migrated from our previous version of the Google Nest Community.  You can continue to receive updates on your thread issue here or simply ask, browse or more in the new Google Nest Community.
Original Poster: Justin Thomas 3149
I've tried to change volume control settings multiple ways. There isn't any rime or reason to it. Plus there isn't any visual volume bar reaction.
Jeran
Hey there Justin,
I'm not too sure I know what kind of Chromecast model you're talking about, are you referring to the Chromecast with Google TV, or a TV with Chromecast built-in? If you are referring to the Chromecast with Google TV, you can check out the advanced sound settings to make sure everything looks and sounds right. However, if it's a TV with Chromecast built-in, you may want to check out your TV manufacturer's website or manual to adjust those sound settings.
Let me know if you had any more questions or concerns for me, I'm always happy to help out.
Jeran
