Pairing the remote problem
Onuryilmaz
I can not pair the remote and the chrome cast device. I tried many several times but there is no solution, the remote signal is always stable and it does not shine
David_K
I'm assuming your Chromecast is already setup?
Try these steps:
  1. Remove the batteries from the remote.
  2. Check that the batteries have charge remaining (i.e., test them in another device).
  3. Using your phone or other remote to navigate, go to Settings > Remotes & Accessories.
  4. Select your remote and choose to Forget it.
  5. Choose Pair remote accessory to start a new pairing.
  6. While holding down the home button, reinsert the batteries.
  7. Continue to hold the button while the light is solid.
  8. When the light starts pulsing, release the home button.
  9. The remote should be detected on the right side of the screen. Use your alternate remote to select it to pair it.
In most cases, your remote will pair automatically after you insert the batteries. If it doesn’t, follow the steps on the TV screen, or press and hold the Back and Home buttons on the remote for 3 seconds.
David_K
Try these steps:
Muddi
Hello Onuryilmaz,
Checking in — I hope davidking's response has helped you fix the issue. Let us know if you have additional concerns about your device and the Community will be happy to lend a hand.
Muddi
Princesss
Hey Onuryilmaz,
Just one quick final follow up since activity has slowed down. We'll be locking the thread in the next 24 hours, but if you still need help, I would be happy to keep it open. If there's more we can do, just let me know.
Princess
Princesss
Princess
