Problem with connecting device
oneMISHAL
Not able to connect with wifi
David_K
Has your Chromecast successfully connected in the past or is this the first time you're setting it up?
Try these steps:
Need help with setup? Troubleshoot common Chromeca... - Google Nest Community
It was successfully connected in the past , but some how , the wifi connection wasn’t connecting any more, so i had to reset it , but still having the problem connecting it with wifi , even though my wifi has no issues , and works perfectly with other devices.
What happens during the setup?
Any errors in the Google Home app?
Did you try the alternate setup steps mentioned in the link above?
