GoogleNestTeam
Community Manager (Admin)
Update 3/20/25
Update 3/17/25:
Update 3/14/25:
Update 3/13/25:
Update 3/11/25:
Hi all,
Thank you.
Thank you for your patience.
GoogleNestTeam
16,160 REPLIES 16,160
Fra1976
Hi, what should I do if I already did the reset of my chromecast?
Thanks
PANORMUS
Data cellulare al 7 marzo
Bertrand2
Any update ??? since Monday now ... maybe you can use AI ?😁
Ostolo
Is there any news? I made a reset already. So please tell me what I have to do now.
Thanks
G00gleGod
Anyone here actually realise that there are several fixes to get your Chromecast....
1* reconnected to the WiFi after a hard reset
2* regain the ability to cast again for Android devices/Chrome browsers
3* change internal debug settings to enable a form of 'root access' and bypass authentication altogether
Do your research people, show initiative and stop sooking on forums wanting attention. I found a solution within 2 minutes of first noticing the issue 2 days ago!!
Yes, I can confirm that the workarounds you mentioned do indeed restore Gen2 casting from Android devices and Chrome browser (sorry, iPhone users). Had mine back up 'n running by Monday morning. Not perfect, but for those who are impatient (and tech-savvy enough), it's a viable option until Google issues a proper certificate fix.
https://www.reddit.com/r/Chromecast/comments/1j7lhrs/comment/mgy1a88/
https://mensfeld.pl/2025/03/bringing-your-chromecast-back/#how-to-fix-it
LaG62
Is this still an issue but I did a factory reset as we had no nbn for days and thought hat was the problem
LaG62
Have set it up but mo casting.
FishShtick
So, when you already reset the device, I assume that there will be a workaround that makes connecting to the authentication possible again? This is getting ridiculous. What takes so long to roll out a fix? Also with RESET ones since you just mentioned it just yesterday? How will my reset Chromecast be able to authenticate once again?
Gracew
I have already factory reset my device multiple times not knowing what was wrong with it. Is it now doomed?
Lisa1703
I did the exact same thing, I guess we’ll see.
Nadja1
Salut je vous remercie
Envoyé moi tout les informations
Car je déjà été réinstaller merci
BenLangley17
Still not working for me.....
FunkyJunky
"Do not factory reset your device" - when my device stopped working the advice that came via your support link was to do a factory reset - which I did!!!
RoiArl
I did a factory reset on mine. Please let me know how to fix this.
mauriciotula
Tarde la recomendacion de no reiniciar de fábrica, es lo primero que te recomienda el dispositivo. 😞
mrrepolyo
"Please do not factory reset your device." too late, reset is part of our basic troubleshooting before checking the web for solutions. Please fix this trust device issue, our grandfather can't watch their favorite boring you tube video.
You can setup the device on a device you set back the time on: that works around being able to install and link it. Now the rest is up to the 'smart' people at Google that have let the world wait for 4 days to use their device.....
Annoyed99
This is not an update, the devices have been down for 3 days now, this is the worst service and  you obviously have no interest in supporting customers.
rubzzen
what a shameful company, Chromecast ko
Alexxxxxxx
Ok so i found a solution, to at least set up the device and use it:
Date back the time and day of your streaming device to a 8th of march.
JuanGarrido
Para los que restablecisteis a "configuracion de fabrica" solo cambiar la fecha del dispositivo a 8 de marzo de 2025 y podreis conectarlo. pero no se puede transmitir. por lo menos ya estaría conectado y si hay solución pues  mejor que esté habilitado.
Mari1984
Hurry.
Petra21
I already factory reset my Chromecast, and deleted it from my Google Home app. What should I do now?
Se puede configurar NO USAR...
Ryanhi
Given the widespread impact, consistent and dependable status updates are crucial. Many of us rely on these devices, and a more frequent update schedule, including a potential ETA for the fix, would significantly reduce anxiety and frustration. Knowing when to expect a solution is just as important as knowing the issue is being worked on.
Radargentina
Realmente inconcebible lo que ocurrió y la demora en comunicarlo y solucionarlo. Ya no compraré productos de Google. Y espero resarcimiento de parte de la compañía. Vergonzoso.
Julian13th
Pls come with a solution asap, as I'm already reset the device 😭
solea
Oui moi aussi et j'ai passé 6h dimanche à essayer de comprendre je pensais qu'il y avait un problème avec le réseau temporaire Chromecast. Il n'y en a pas pour des jours à faire les MAJ nécessaires
CreakFFM
thats crazy. my girl tell me since 3 days its not working anymore.. fix it quick google
Anonymous
Not applicable
Google need to learn "if it's not broke, don't fix it". I'm still waiting for a fix on the 'away' functionality for my Google nest thermostat also.
MrJazz
They've changed it to"if it ain't broke, BREAK IT!"
PANORMUS
Dopo il reset non si vedevano piu' .Ho messo la data del cellulare al 7 marzo e li ho configurati e si vedono ma non funzionano .Restiamo il attesa
Fabio76
Salve io ho resettato entrambi le cromocast come posso riempostare?
Jonathan_Pei
I performed factory reset. Please reply to my query raised one day ago.
Set the clock to 8 march on Android Phone (doesnt work with Iphone). Connect chromecast again. Then power the chromecast off and on. (remember to update to newest version of Google Home). Worked here....
Chrisbear
Sadly not for me. Returned an out of date firmware message
mikekaast
Hi. It would be so nice, if you send a mail or a notification AS SOON the FIX is ready, and can be applyied to the chromecast. And what do all of us do, after we HAVE MADE THE FACTURY reset, as Google help page says ??
Hope this will work soon, i'am so happy with my chromecast.
BR. MK.
mkhwinana
How far are we with the fix?
