GoogleNestTeam
Community Manager (Admin)
Update 3/20/25
Update 3/17/25:
Update 3/14/25:
Update 3/13/25:
Update 3/11/25:
Hi all,
Thank you.
Thank you for your patience.
GoogleNestTeam
16,136 REPLIES 16,136
chunteewe
Looking forward to a fix.
Thank you.
Brando1234
I already factory reset now what
Anonymous
Not applicable
In English:
1) Change your phone's date (before 9/3/25)
2) Complete the installation from the Home app
3) Install Activity Manager, go to the Launcher option, then to "Action," paste the following: com.google.android.gms.cast.settings.CastSettingsCollapsingDebugAction, then click the "check" button
4) Enable the Bypass Certificate option
5) You're now ready to use your Chromecast
Oh, I found a link to these steps, attaching here for reference..
https://www.androidauthority.com/how-to-fix-chromecast-authentication-errors-workarounds-3533849/
can't change iphone dates
Anonymous
Not applicable
1) cambia la fecha de tu celular (anterior al 9/3/25)
2) desde la app Home finaliza la instalación
3) instala Activity manager, ve a la opción laucher, luego a "action" pega lo siguiente: com.google.android.gms.cast.settings.CastSettingsCollapsingDebugAction, luego dale a la "palomita"
4) activa la opción omitir certificado
5) ya podés usar tu Chromecast
Cymer
Muy difícil!!!
MarcioCarqueija
Só conseguir descobrir hoje que o problema foi reconhecido pelo Google, espero que volte a funcionar com brevidy
Felemberdico
I have already reseted It.
So i wait for your fordware instructions.
Please keep me updated.
UNIQUEVIBES
How is this going to take ffs . Why's my sons chromecast working and mine ain't
UNIQUEVIBES
What **bleep**in answer
095
Pasa lo mismo con 3a gen??? No logro configurar y lo he reseteado!!!
fasosl
Waiting for the fix
Molina2025
When Chromecast is working properly our Chromecast is not working
JOS7
Bro, just CTRL + Z
This is unacceptable.
dgwalizer
As a work-around, I've found that configuring the chromecast  device as an Open Home (DLNA) renderer with bubbleupnp allows you to cast to the device as a DLNA renderer.
Cymer
How long will it take? 4 days it's already a lot!!!
Concerned
I factory reset before seeing this. Am I hosed now? I really love this device.
HauntedinNY
I went out and bought a Wi-Fi capable TV and now I don't need Chromecast anymore. I'm done waiting. Five days is too long to wait.
Chantala
When is the service going to be back up?
F8G5
f8g5
UNIQUEVIBES
Still bloody troubleshooting
UNIQUEVIBES
Chromecast troubshooting
Antonio_Cantu
Please fix It asap, how can we know when this be fixed? Are you going yo send a notification, email, etc.?
This is absolutely ridicules.  It's going on 5 days and still nothing????  I have to get the kids system up so I guess it's time to get something that works.
Rafaella
Não consigo conectar ele com meu celular, qual ser o problema?
Maru79
Muchas gracias! Espero que se solucione rápido el problema y me informen así puedo volver a usar el dispositivo. Nuevamente, muchas gracias!
Mariangel
Hola, estoy teniendo problemas con mi cromcast.  Lo e restaurado de fabrica porque hace varios dias vengo sin poder usarlo y arroja un msj qué no se logra la autentificacion. Como puedo solucionar?
DanielleLucena
Infelizmente resetei o equipamento, por favor o que fazer agora,  pq tento seguir os passos a não resolve mais!
vanesaschwemmle
  • También restablecí mi dispositivo a la configuración de fábrica, pero encontré la manera de dejarlo como estaba, pero sigue sin conectarse al televisor. Lo que hice fue ir a Ajustes, General, Hora y Fecha en mi iPhone y cambiar la fecha al 7 de marzo de 2025, antes de que caducara el certificado. Configuré Chromecast como siempre y todo volvió a la configuración original. Sigue sin conectarse al televisor, pero al menos está listo para cuando se implemente la solución.
Vanessa, vou tentar. Vamos aos passos, 1 mudo a data do telefone?abro o app home e  configuro o equipamento sem conecta-lo a TV?
Jorgemorenor
Send me the information, because did the factory reset.
Maddiegirl64
C'mon Google. My devices have been down since Monday afternoon. It's now Wednesday night. How bad was the hack? And what personal  information was stolen?
Nothing to do with a hack?
MarceloM1979
Although I was able to bring back my devices by using an android tablet with the date tweaked to  March the 1st, all of the devices are offline... aaaaaand then also I'm noticing that my chrome is not picking up the broadcast icon while on youtube when I have a LG 65" TV that has the ability to pick up broadcasts... maybe related, maybe not... any idea on E.T. for the fix?
Martinbarriga83
Last Monday I brought a Roku device on Amazon, it will come from Amazon USA to Mexico tomorrow, I think that 4 days is enough to wait. I lost the hope to use again Chromecast, I guest that google wants to sell new products but if they can not fix this right now we should not buy another google tv device.
MeliSalatin
Sorry, Ive already reset my device. So I'll wait for the instructions as soon as possible. Thank you
Emerson_emmalve
Se não é para restaurar, porque ainda mantém essa instrução na página de ajuda deste dispositivo. Há uma contradição aí sobre essas orientações.
Arqbrown1954
Lamentablemente micjos usuarios no tuvimos aviso y reseteamos el dispositivo
Que podemos hacer?
Luxess
combien de temps pour régler le problème devons nous allez acheter un autre cast avec autre compagnie.
