GoogleNestTeam
Community Manager (Admin)
Update 3/20/25
Update 3/17/25:
Update 3/14/25:
Update 3/13/25:
Update 3/11/25:
Hi all,
Thank you.
Thank you for your patience.
GoogleNestTeam
16,146 REPLIES 16,146
Same issue here, Minnesota
Same issue here. And of course I followed their steps that says factory reset it and retry, but now i cannot even connect it to my Wi-Fi network. If they want us to buy new devices they should allow us to return the completely fine working devices and trade them, for a cheaper price.
True.. I need 2 devices cause you can't cast through a PS..
Lo mismo Cd Juárez México 🇲🇽
Same issue
Same issue, would appreciate answer to issue when available
Same with me. Any update about this how to fix this?
Same in California.
Still no fix?   They can't just brick out our device like this
Hola yo tampoco puedo... Cuando se va a poder arreglar ésto??? Gracias
Chromecast is rubbish. Mine doesn't work more often than not. Waste of money.
It's a shame Google aren't as interested in resolving issues as they are in handing out BS badges.
Chromecast desde domingo dia 9/3/25 parou de funcionar abruptamente, quando ele estava antes bom. Não encontro qualquer atualização do Google para o problema, mas é um produto Google e ele tem a responsabilidade de resolver tal qual teve a responsabilidade de me vender.
The same **bleep** happen to me…in Italy, it doesn’t work. Nothing…customer care inexistent…
Hi
facing same issue with chromecast gen 2.😞
Same here.
I have 2 2nd gen Chromecast that stopped connecting the wifi.
My google Nest works perfectly, but the 2 old ones keeps showing as offline.
I tried the factory reset, but it doesn't connect to properly working wifi.
Any chance to have an answer?
Found a Work Around for me
My Amazon Fire Stick works fine
Google should have resolved this issue by now which makes me think it's INTENTIONAL
Chromecast authentication issue, here’s the latest update as of March 12, 2025:
  • Current Status: The authentication error affecting second-generation Chromecast and Chromecast Audio devices is still ongoing. This issue, caused by an expired authentication certificate, prevents these devices from connecting to Wi-Fi or completing setup, especially after a factory reset. Google has acknowledged the problem and is working on a fix, but no official solution has been released yet.
  • Temporary Workaround: Some users have had success with this temporary trick to bypass the certificate issue:
  • On your phone, go to Settings > Date & Time and turn off automatic date/time.
  • Manually set the date to March 8, 2025 (before the certificate expired).
  • Open the Google Home app and try setting up your Chromecast again.
  • If it connects, switch your phone’s date back to automatic.
  • Note: This workaround isn’t guaranteed to work for everyone, and even if it does, some apps might still have trouble casting. It’s worth a try, but you might need to attempt it a few times.
  • Avoid Further Factory Resets: Google has advised against performing factory resets on affected devices, as it can make recovery harder. If you’ve already reset your device, avoid doing it again.
  • Monitor for Updates: Check Google's support page and forums like r/Chromecast for the latest news on a fix. Since this is a widespread issue, a solution should be on the way soon.
  • Need More Help?: If you’re stuck and need assistance right away, reaching out to Google support might offer more tailored advice for your specific case.
  • If you or anyone else needs further help, feel free to reach out—I’ll be here to provide more info or support as needed!
Same for my home TV with chromecast device was working till march 10th then after gone , it’s not working anymore
Same thing happened to my Chromecast. What's going on everything was fine last week.
Having same issues past 3 days driving me crazy. I tried factory reset no avail 😕
My tv won’t cast issue with firmware
please let me know when. You get it fixed
at my e-mail address Please hurry!
Sou do Brás e está acontecendo o mesmo comigo.
All mine have disconnected. They are connected to my wifi network, but showing as disconnected in google home. YouTube music is suggesting an outdated firmware issue
Rishi17
Even after 12 hours same status not working - no solution
tried calling got a call but no one available
seems like they have stopped the support as well
Same thing here in Texas.  Factory reset and still will not authenticate.
JoTexas
By the by, I use a NC2-6A5,
Firmware: 1.56.275994
JillG
Hello everybody!
OOF. Seems to be a very widespread issue. FYI, the Community Specialists have been notified and I pinged our Community Manager.
Appreciate all your posts and info and they will see each reply.
HOPING for a really quick fix.
Jill
Mum1
It's been 9 hrs since you've posted this and mine has just decided to have this problem 30 mins ago in Australia. So how long is this going to take?
I am having the same issue, 3 chromecast audios showing offline, I removed them from my home app, did a factory reset on them, robooted my router, connected from the same 2.4ghz network, cleared app cache and storage, tried to readd them, but get a "we couldn't authenticate" message. Can't check firmware version because the home app shows it as offline despite one still being connected to my router's wifi
Similar work flow. But with Chromecast instead of Chromecast audio
My chromecast stopped working. Is google punishing me for watching porn last night? 😄
DropbearRob
They know from the type of porn that you'd enjoy being punished. So no... They're far more sadistic than even the porn you were watching last night.
Malmö, Sweden. It's the same crap going on here. And the only, useless, so called "help" that is available in the help pages of chromecast.com doesn't address the problem.
PelleJ
I have  the same problem in  Jönköping, Sweden. Gen2.
Acabou de acontecer comigo, Já tentei de tudo! Reiniciei o Chromecast no modo fabrica, Desintalei e instalei o Google Home e tentei configurar a Casa, mas quando vai conectar no Chromecast dá a mensagem: " Não é possível autenticar o Chromecast. "
Minha dúvida é que se o Google parou de vender em 06/08/2024, eles vão dar suporte para eates aparelhos da segunda geração?
