Update 3/20/25
Update 3/17/25:
Update 3/14/25:
Update 3/13/25:
Update 3/11/25:
Hi all,
Thank you.
Thank you for your patience.
03-20-2025 10:49 AM
03-13-2025 02:00 PM
I done the factory reset but, after, I reconnected chromecast to my WIFI by using a phone with date reversed before 8/3/2025. I will receive the fix in this case or no?
Thanks
Bye
03-13-2025 02:00 PM
Maybe quicker information to your customers before making people reset chromecast to factory settings? Kind of annoying to spend hours trying to fix something you already knew were pointless.
03-13-2025 02:00 PM
No funciona mis Chrome cast!!! Cómo hago para que vuelvan a funcionar???
03-13-2025 02:01 PM
Restaurei de fabrica agora não entra mais
03-13-2025 02:01 PM
For those who reset their device to factory. Kindly setup your device again by changing your date to 08/03/2025 of your android phone in order to receive a fix for a device.
03-13-2025 02:02 PM
I reset my Chromecast and now it won't reconnect what do I do please
03-13-2025 02:02 PM
Para los que no reseteamos el Chromecast 2da. Generación:
A las 20:30 GMT el problema se ha solucionado al desconectar y volver a conectar el dispositivo.
Tras una actualización en pantalla con barra de progreso, el Chromecast 2da Gen ha vuelto a funcionar normalmente.
Google Home lo reconoce perfectamente y se puede nuevamente volver a transmitir como antes.
For those of us who didn't reset the 2nd Gen Chromecast:
At 8:30 PM GMT, the issue was resolved by disconnecting and reconnecting the device.
After an on-screen update with a progress bar, the 2nd Gen Chromecast is back to normal.
Google Home recognizes it perfectly, and you can stream again as before.
03-13-2025 05:15 PM
This is exciting news! You appear to be the only person on here who has received the fix though! I'm surprised that Google haven't updated the status to say the fix is available. You say 8:30pm GMT....are you in the GMT timezone? I'm one of the people who did a factory reset & I've been waiting to see Google confirm a fix rollout before doing anything more, including the "time-travel" step that is being pushed so much on here. I'm not very techie, so although I get the idea of it, I think I'd prefer to have Google instruct me to do it before messing with the date on my CC.
03-13-2025 02:04 PM
I'm sorry but this is unacceptable. As someone who works in tech support, this should be resolved already. The fact that you still don't have a resolution for those us of us who followed your companies direct instructions to factory reset, leaving us with nothing on multiple Chromecasts ( almost a week & counting ) is disappointing. I will NEVER buy a Google Chromecast or a Google product again. How this whole situation was handled & continues to be handled, is unacceptable. Transparency, honesty & efficiency are 3 things I would expect from Google, but the company failed at all 3.
03-13-2025 02:04 PM
Not good enough.
03-13-2025 02:10 PM
So assuming that the chromecast was broken I threw it out and spent £60 on a new one for nothing?
03-13-2025 02:13 PM
Bonjour combien de temps cela va t'il prendre
03-13-2025 02:13 PM
O problema é que quando foi pedida a atualização e não deu certo, a primeira coisa que 100% das pessoas com problema fizeram foi restaurar para as configurações de fábrica porquê o problema foi identificado primeiro pelos usuários e não pela própria Google. E mesmo após identificado por vocês, demoraram dois dias para enviar notificações para não fazermos a restauração.
03-13-2025 02:14 PM
Reinicio el chromecast ahora no me permite configurar a la tv, sin embargo lo tengo conectado. me podrían confirmar si se va actualizar el dispositivo?
03-13-2025 02:20 PM
this has been an ongoing disruption for months by now and it’s been irritating not be able to use my chrome cast. I feel there should some type of compensation for this obscurely long disruption/error.
03-13-2025 02:19 PM
Sigue sin funcionar !!!!! Que debo hacer ???? Esto me tiene harta !!!!
03-13-2025 02:23 PM
How many days will it be okay?
03-13-2025 02:25 PM
zzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzz
03-13-2025 02:27 PM
Aún tengo problemas con mí chromecast
03-13-2025 02:29 PM
Thanks for the fix.
My 5 devices are working again.
03-13-2025 02:36 PM
Mind if I ask how? Did you do a factory reset and then the change date trick or what happened?
03-13-2025 02:31 PM
Please advise what the problem is as simply saying that you are trying to fix something without advising what is daft
03-13-2025 02:33 PM
Me encanta el desentendimiento del problema generado y que le "hechen la culpa al usuario que restableció de fabrica" . Haganse cargo de la situación dejo de andar el 9. En todas las ayudas del sitio decia si no puede solucionar, desconecte el cromecast y el router, si no se solucionó pruebe resetear de fabrica.
Y un dia después postean "No recomendamos esa acción' . por lo tanto si lo hicieron esperen no se hasta cuando... Estamos trabajando y bla bla...
03-13-2025 02:32 PM
This is embarrassing for a “Tech Giant” to not have a contingency plan in place for their product and software. Also waiting two days to address it, I’m sure nearly everyone has tried to reset it to get it back online.
I have three of them and they are useless until they have the fix for if you reset them.
Really glad I didn’t change over to their phone this year, I wouldn’t have days (or weeks) to wait while they try to make something I bought from them work.
03-13-2025 02:34 PM
Paola becerra45678
03-13-2025 02:35 PM
Mistakes happen, but please send an email to Google accounts that have a Chromecast linked to them. I wasted 4 hours of my life until I found this.
03-13-2025 02:37 PM
Eu realizei a redefinição.. como procedo?
03-13-2025 02:39 PM
how we can access to the solution? Would you automatically update the device? Should we keep the device connected & on? Please inform users about the method of accessing to the solution. Tnx
03-13-2025 02:46 PM
Keep your Chromecast connected to a power supply.
03-13-2025 02:37 PM
Hello, unfortunately I threw the device in the trash thinking it was broken. 😔😔😔
03-13-2025 02:41 PM
thanks my cc audio and video both working again
03-13-2025 02:42 PM
Mine is working again!!! 😃😃😃
03-13-2025 03:30 PM
No way! Hope mine is soon! 🤞🏻
03-13-2025 02:46 PM
Well darn...poop on me for factory resetting the thing during my failed troubleshooting.
03-13-2025 02:57 PM
For those who reset their device:
Go to your phone or tablet settings and set the date to before March 9. Then, open the Google Home app and set up your Chromecast again.
Once you’ve finished reinstalling and configuring it, change your device’s date back to the current date. When you try to cast something to your Chromecast, you’ll see a message saying that the firmware is not up to date.
This process will restore your Chromecast as if it had never been reset. This is just a workaround to get it set up again while we wait for Google to fix the issue.
03-13-2025 03:51 PM
Very useful!! Thanks for the tip! It worked!
03-13-2025 02:44 PM
Fix it ASAP please. This is a nightmare.
03-13-2025 02:52 PM
Oh no! I already performed a factory reset 😭 Hope the issue will be fixed soon 🙏
03-13-2025 02:52 PM
I do hope you guys can get it fixed before tomorrow night, because I do watch a study live on there and I’ll have to watch it on the small phone screen if it doesn’t. I mean, it’s fine, just not good for study
03-13-2025 02:53 PM
Hola Google si hicieron el factor y reset para volver a configurarlo sólo deben poner fecha de 8 de marzo en sus móviles y volver a levantarlo. Luego solo queda esperar la actualización
