GoogleNestTeam
Community Manager (Admin)
Update 3/20/25
Update 3/17/25:
Update 3/14/25:
Update 3/13/25:
Update 3/11/25:
Hi all,
Thank you.
Thank you for your patience.
GoogleNestTeam
16,122 REPLIES 16,122
Funciona pero sigue fallando la aplicación y no me permite conectar con ninguna app
HAY ALGUIEN QUE PUSO GRACIAS GOOGLE... JAJA
UN MASOQUISTA?
ME CAUSÓ MUCHA GRACIA
En cuanto tiempo estará la solución?
And now? Still no update and I did a factory reset.
No puedo creer que esta solucuon se demore taaanto.
Resetei meu dispositivo para configuração de fábrica antes de saber do problema, como faço pra resolver?
Hi there, Now, Google Home app is also not getting downloaded from playstore.
Now is one week and u cant still to fix this? Why so slowly?👎
Still haveing issues with not setting up , I did do a factory reset , and still not working
Anonymous
Not applicable
When is there a fix for us who tried to factory reset?
Bonjour,
J ai acheté cette chrome cast il y a maintenant au moins 4 ans et j en prend grand soin .
Tout ce que je d'amande c est que ça fonctionne et vite car ça commence sérieusement a m'agacer.
Réglez le problème rapidement ou envoyez moi une chrome cast qui fonctionne !
Merci
“Your device must be connected” - what can I do to reconnect it? All options to connect don’t seem to work (via BT “connection failed”, when using the wifi route, I cannot see my home wifi when I need to connect). I didn’t perform a reset
All resolved for me - even the one that I carried out a factory reset on is now sorted 👍👍
Anonymous
Not applicable
I solved it ... Even though I reset the device I managed to get it to reconnect to my wifi network by changing the date on my smartphone to March 7th
Once the connection was established it did the update (I think the new certificate) and I managed to get it to restart.
I’ve been trying to figure this out for months how have you not fixed it yet, it jsut told me what to do I follow every step and it does not work every time and I jsut broke my entire toilet and outlet bc I threw it as hard as I could. Plz fix this soon I jsut want to listen to music
You've had a week and this still isn't fixed. I'm going to get an Amazon fire cube. Ta ta Google.
Quem redefiniu oque deve fazer para voltar a funcionar
Ainda continuo com o problema pois resetei meu aparelho
In germany is working again!!!! I did reset, then march 3. Then added. Then again todays date and waited  twenty min, I think it was updated in this time and now i am watching TV show!
Is there an update for the people who factory reseted
Nest75
Does it show your Chromecast in Devices ?
No need to mess with system date, Goole fixed that
Nest75
Step 1 (most important)
Make sure you are connected to your google account on your phone (in the Google home app) at top right corner on the phone
That will give Google access to your Chromecast so they can upload the software fix (for this you just wait)
If you have factory reset your Chromecastn set the date onyourphe to 1st March  2025, add your cheromecast to Google Home in the normal way.  Follow the process, when it gets stuck, close Google Home and reset the fate to Automatic. Reopen Google Home and the chromecast.
Worked twice for me, I hope this as helpful
Anonymous
Not applicable
Like many others, I have reset my Chromecast to factory settings, but nothing has changed. It’s a really big inconvenience for me…
Quando será corrigido isso? Estamos aguardando faz uma semana!
Um dos chromecast eu havia redefinido as condições de fábrica na tentativa de fazer funcionar no domingo, antes de saber do problema que afetou todos segunda geração. Dois outros chromecast já estão funcionando, porque eu não havia tomado nenhuma atitude, desconfiando que algo grave havia acontecido.  Como devo proceder para restabelecer conexão com o chromecast que retornei a condição de fábrica?
Qual a previsão?
It's Saturday afternoon and still not working?!
Please update on folks who did factory reset
Para quem ainda está tendo problemas e assim como eu, restaurado ao padrão de fábrica, solução possível (deu certo aqui)
Mude a data do Celular para 03/07/2005,
Faça as configurações no Google Home, o Chrome Cast vai atualizar, depois é só colocar os dados certos no celular.
Problemas com meu chromecast não.consigo configurar
Ça ne marché toujours pas, et ça va faire  une semaine.
Når vil det fungere?
Lo restableci de fabrica y ahora no me reconoce el dispositivo solución urgente
Alguma solução ou receberemos o valor pago de volta?
Poxa, é decepcionante ter um aparelho que sempre usei, e agora simplesmente não consigo mais.
Em consideração a todos clientes que usam o produto, isso deveria ser consertado.
Yo lo he restablecido antes de saber de este problema. Ahora no va. Que van a hacer para solucionarlo porque yo he pagado un dinero
O meu da mensagem que o frame está desatualizado, tenho 3, precisam de uma solução rápida.
Yep still cannot re-setup device...😒
Resertei meu Dispositivo pois achava que fosse um erro do mesmo, só depois que tive a notícia do problema e agora meu dispositivo não vai mais funcionar?
