GoogleNestTeam
Community Manager (Admin)
Update 3/20/25
Update 3/17/25:
Update 3/14/25:
Update 3/13/25:
Update 3/11/25:
Hi all,
Thank you.
Thank you for your patience.
GoogleNestTeam
16,155 REPLIES 16,155
WHAT IS HAPPENING WITH THE FIX??? Any news??? It takes way too long!!!!
its still showing same issue as I done reset before reading your advice what should i do now ?
Hello GoogleNestTeam - I was able to get update after changing the date to March 5. I was able to set it up again in my GoogleHome. Even though i am in the same network, it still says "Not Available".
Is the issue still happening? What is the resolution time here?
Please advise thanks!
It really upsets me that the information to not factory reset didn't come out until 2 days after the issue started and by then I had already started and I had gone through all the troubleshooting steps on the website including the factory reset. The communication from Google on this issue has been absolutley piss poor. I down have an antenna at my place nor do I have a smart tv so chromcasting to the tv is the only way we can watch anything. I have recommended this product to others and even purchased one for my nana and father in the past couple years. Don't I look stupid now recommending this product. I've always been a huge supporter of Google and their products but the poor way in which this has been dealt with and lack of planning on their end shows very little care for their customer base.
I agree with you re the troubleshoting instructions on the website advising to factory reset. It's pathetic 😒
I tried what other have recommended, set the date for the 7th March and reconnected my Chromecast to the Google home app. Connected it to my wifi. The update was downloaded and the Chromecast works now.
Lo único que tienen que hacer es establecer en el celular una fecha anterior al 09/03/2025 (fecha en la que venció el certificado) y ahí les va a permitir configurar nuevamente el Chromecast de 2º Generación y automáticamente se va a actualizar el firmware actualmente lanzado por Google, corrigiendo el problema si es que habían restablecido de fábrica el Chromecast. Luego pueden restablecer la fecha automáticamente que ya estará solucionado el problema. Saludos!
Will the software be updated if the Chromecast is plugged in, recognized as being on the LAN but with an "off line" status?  I re-booted the dongle but didn't do a factory reset.
Where is to resolution if factory resetted already?
WHEN WILL MY CHROMECAST BE FIXED!!!
Hi. When will my chromecast be fixed. I have asked for a response several times but still nothing. What the f$#ck are you guys doing?
Avevo fatto il reset e quindi anche io ho fatto come consigliato: cambiato manualmente la data del cellulare e settata su 01/03/2025. A questo punto, cominciando la configurazione Chromecast si è aggiornato e la configurazione è andata a buon fine! Ricordate poi di rimettere l’opzione “ora e data automatiche” sul cellulare. Grazie a tutti!
It works 👍🏻☺️Thanks
awhrn can we expect the update this is ridiculous..
I had the same problem with my Chromecast (2nd Gen) and iPhone in Germany. Here's what worked for me – no guarantees!
1️⃣Connected the Chromecast and waited for it to boot.
2️⃣Manually set the date on my iPhone to February 17, 2025.
3️⃣Opened Google Home and started the Chromecast setup.
4️⃣At the final step, the screen showed that it was trying to connect, but pressing Next didn’t work.
5️⃣Closed the Google Home app completely.
6️⃣Kept the Chromecast plugged in and reset my iPhone’s date to automatic.
7️⃣After a few minutes, I reopened Google Home, and suddenly, my old Chromecast (2nd Gen) was back – working again! 🎉
It is working , thank You  👍🏻☺️
Oh how I wish this would have worked for me. Unfortunately when I changed the date and time it then wouldn’t connect my phone to the wifi 🤦‍♀️🤦‍♀️ lost all internet connection
Maria65
Did you just go back to March 7th? I saw where people went back a year😕 and that didn’t work.
Is it working again, if You have reset the device?
Yes, just try to customize date to 7th march and setup as usual
HU47DA
Thks PRAB_tech
Please advice how to customize date?
We have a problem with the volume buttons
It changed after the latest Chromcast update
On my phone I can't adjust the volume as I want, it usually shows a separate CC icon
Anyone else have the same problem?
Any updates on what to do if you’ve factory reset the chrome cast before the issue was resolved?
Broadwood
Manually set the date back 14 days on your phone. Then it will connect to your wifi and promptly auto-update itself.
Still unable to finish set up.
please advise when fix for factory restore will be available?
Any updates since Thursday? Still have the same issue
Still waiting... is there anything going on...?
SOLVED !!! Chromecast 2 gen.  Had factory reset at first.  Set the phone clock manually before March 8th. Was then able to connect to wifi but still not casting.  Then Google must have release an update as Yesterday (3/16) the device automatically dowloaded it and now it works perfectly. Thank you.
Cortese supporto, ho fatto richiesta di csupporto e sono stato contattato dai Vostri tecnici telefonicamente i quali mi hanno fatto fare il ripristino del dispositivo ed ora non riesco ovviamente più a connetterlo alla rete e ricevere l'aggiornamento necessario!
Vi invito a risolvere quanto prima il problema poiché ripeto ricevo il messaggio "Impossibile comunicare
con il dispositivo
Chromecast" e quindi sono bloccato
Grazie
Se l'hai resettato come ho fatto io, cambia semplicemente la data del telefono all'8 marzo o prima e avvia il processo di configurazione del tuo Chromecast dall'app Google Home. Sfortunatamente, questo non risolve ancora il problema del casting, ma ti lascia nella schermata dello sfondo del Chromecast in modo che possa ricevere l'aggiornamento.
Hi. Unfortunately I didn’t have power on my Chromecast + Audio and wasn’t aware of the roll out. I have had power on the devices since yesterday and they still don’t work.  What can I do?
we have ALL factory reset our devices as that's what YOU advised us to do! I have had no TV i for 11 days now as i ONLY stream. FIX this!!!! you're a billion pound company!
joelios
If you resetted it like I did, just change your phone's date to March 8th or earlier and start the process of setting up your Chromecast from the Google Home app. Unfortunately, this still doesn't fix the casting issue, but it does leave you on the Chromecast wallpaper screen so it can receive the update.
Manually reset my Pixel 7 on March 5th and reinstalled everything. Everything works again.
For thoes who reset their chromcast like me. Manually change the time in one of your device to for ex 25th Feb, and start the setup and you will be connected again, you can receive the update and your device work again, I just did it today.
How can I do this?  Change the time? In my phone? Or Chromecast?
On the phone, disable automatic sync date/time and force the date before 8th march
How soon can this be fixed please?
Hi I have the additional problem of my WiFi Modem collapsing as well, so I have been forced to get a new modem, so it cannot link at all. Are you able to send me a patch for that once it is up and running again. I think I have a Gen 2.  Kind Regards Sandy
