GoogleNestTeam
Community Manager (Admin)
Update 3/20/25
Update 3/17/25:
Update 3/14/25:
Update 3/13/25:
Update 3/11/25:
Hi all,
Thank you.
Thank you for your patience.
GoogleNestTeam
16,151 REPLIES 16,151
This works! Thanks!
Brilliant! And ya, WTF, why doesn't Google have this in their answer? It's not like we're messing with the fabric of time here 😂
Funktioniert bei mir leider nicht!
I promise you, it works. Re-read the instructions and try it again.
Deu certo, já estou conseguindo transmitir para a tv, obrigada
Thx Johnny zero,, that works 💪🏼💪🏼👍🏼👍🏼
Worked perfectly! Thank you!
Thank you! Chromecast is working again... even though google home is still saying it isn't connected 🙂
Yes, the Home app will still say that it's disconnected until it receives the firmware update fix. Once that's installed, it will restore full functionality. Be patient.
não funcionou .!!
Re-read the instructions and try it again. I promise you, it works. See posts below.
I tried this and it did not work for me
Jue1
Up and running 🏃‍♀️ thankyou so much 😊😊😊
I tried this several times on both of mine & it still fails. I get closer then b4 but then it fails .
Keep trying. I promise you, it works.
Tried this steps and my chromecast updated. It's finally working.
Yes, it worked. Thanks.
Waiting eagerly for fix to be rolled out now...
Good. Also, some are reporting that you can somewhat "provoke" the update by power-cycling the Chromecast (unplug/re-plug the power cable).
Funcionó! Gracias
Doesn’t work
I promise you, it does. Re-read the instructions and try it again. Good luck.
Funcionou e sim, tá conectando normal, voltou a funcionar normalmente... Muito obrigado e sim o Google devia fixar esse tutorial... Devia tbm te dar uma carga lá, pq eles até agora não avisaram que tinha retornado nada e não deram solução alguma .. parabéns novamente e meus mais sinceros agradecimentos...!!!!
Anonymous
Not applicable
@GoogleNestTeam if this is the fix then please pin it to the top of your page and forward it to users since many thousands of them are victims and if we actually tried to solve our problem and did a factory reset (as advised by Google as a normal problem solving step) then we still haven't received a fix or advice what to do. While many apparently have been able to fix the problem apparently with these steps.
Right? Literally every other person on this forum is asking how to recover from a factory reset. I sure wish they would pin this information at the top. I'm getting tired of posting it. 🙂
Vc trabalha para o Google?? BertVV está certo. Enganar o Chromecast pode ser uma ação momentânea. Mas queremos a solução definitiva para o problema. Google é que deveria estar a responder aqui.
Yes, it's a clever trick to temporarily get around the expired security certificate. I'm sure Google will eventually come up with a more elegant solution. But I assume most people here would rather not wait for an "official" fix.
Nest75
You do nothing, just leave the Chromecast power on and wait, then occasionally open Google home app and check the status
Not true. Anyone who has done a factory reset will first need to do this to get it back online, or else it will never receive the firmware update fix:
https://www.googlenestcommunity.com/t5/Streaming/Regarding-an-issue-with-Chromecast-2nd-gen-and-Chro
Hola! Mi Chromecast se actualizo hace una hora, pero sigo sin poder transmitir nada. Debo seguir esperando algo más?
Hice eso conecto se actualizó pero no puedo transmitir desde mi celular al dispositivo por más que este conectado
I used your advice. And it worked. Thanks for your help
How do you set the date on I phone
Settings, General, Date and Time
Thanks so much, it worked I don’t have to wait for goggle to update me about fixing the issue anymore!
Unfortunately that fix didn't work for me. I am having to hit the 'patience' key and watch my programs on the ipad.
Breck21
Just wait and don't do anything. Don't press the patience key give it 10mins then turn the date back to today and should work.
Did this myself this morning : chromecast updates right after connecting to wifi and all is working good now !!
It worked for us. Thank you very much!
Solution worked..Thanks.
Anonymous
Not applicable
@johnnyzero2 thanks for your advice and for your efforts to spread the word to many of us. I was also able to reconnect the Google Home app to my Chromecast after temporarily changing the date of my phone to 1 March (Samsung with Android). Still hoping @GoogleNestTeam will communicate this workaround as soon as possible to everyone while they work on an complete fix. It shouldn't have to be the responsibility of a single user to inform more than 12,000 users about the workaround (and every day 1,000 more who have the issue let alone who didn't find this post).
