GoogleNestTeam
Community Manager (Admin)
Update 3/20/25
Update 3/17/25:
Update 3/14/25:
Update 3/13/25:
Update 3/11/25:
Hi all,
Thank you.
Thank you for your patience.
GoogleNestTeam
16,145 REPLIES 16,145
Szezán
Szeretlek kicsim
Szezán
Köszönöm
Fixthisnow
Thanks Guys for rolling out the fix. In the meantime read this
RyotaSaito
もうリセットしてしまいました。
ごちゃごちゃわかりにくい説明文と、セッティングにするくらいなら、『リコール』扱いか、現在のモデル大幅値引き&無料配送位のサービスをやって下さい。Google規模の大メーカーなら、このくらいの事たやすく実行できると思います。(日本のクルマメーカーは、リコール扱いは無償でおこなってくれます)
Aaditya
my device promblem connect to TV but not display
なおみ
リセットしてしまいました。いつ解決しますか?iPhoneに反応しません
JoarB
Please add a MONO option in settings 🙏🙏
Just sum right and left channel and make them play the same. A lot of people are using these to play music in e.g restaurants and with multiple speakers spread out where stereo sound is not wanted.
Car02
Por favor!!! Necesito que arreglen esto... avisaron tarde que no había que resetearlo por favoooor! Ya todos los hicimos!! Hace una semana que estoy sin poder ver nada en la televisión!...
Marina5
De acuerdo
Kelly45
I am still having issues!
9511600945
The chromecast is not working
Pakibad
Speriamo davvero di non doverlo cestinare .
Anonymous
Not applicable
I don't know the issues I do Factor restore now stuck it in process plz give the update solve the issues
Anshuindia
Has it been fixed
Saipo
Thank you for not letting us watch tv for the weekend. We are now so fed up by Googles obvious resistance to fix this, so we will now start finding options for everything we have with Google. 5 days only shows that you dont give a **** about fixing the problem. Very disrespectful to loyal Google users. Sayonara Google and good luck with ignoring the users.
JM1994
Is there solution for the devices that have been reset yet?
Cnr1
Hi everyone, I’ve just changed the date and time on my phone to the last time I could cast 8/03/2025, I’ve reconnected my chrome casts back to my internet and now awaiting the update from google, I hope this helps everyone that had already done a factory reset.
Bhaskaran
I deleted the device from Google hoke app. I am unable to reset it. What should I do now?
I was able to go back to before the factory re-set by following one of this post advice.
1 Set my cell to 8th of March (before the new certificate)
2 Install the Chrome cast anew using Home
3 Set back to the automatic date mode your cell
This way when Google deploys the fix you will catch up it.
Apermyr
And if add process stop.
Connect to chrome wifi manually and then restart add process
Tomlausanne
How can we know when it will be fixed? Can you email us ?
koenbrug
Ive bought a google streamer device 119eur because of this issue. Can i get a refund?
Goldie2
I have already factory reset my device, as it's the first thing we are told to do. Now what??
Anne1995
 Ich hab seit drei Tagen auch das Problem das Chromecast sich nicht verbindet und nicht funktioniert bitte beheben sie es so schnell wie möglich
Leeleeuk
How on earth is this possible to be down with someone like Google a major factor on review platforms
Debblybum
Useless, ive spent days trying to make it work to finally see this information. You guys need to get better at communicating your faults.
JartoG
You break it, you pay it. Please, send a new one for free!!
Sanctuz
Haha, if they would be so kind-- me too please 😂
I need 3 of them
Sanctuz
... What if I have already factory resetted..??
*Gulp*
ATS
もう使えないかと思ってファイアTV買っちゃいましたよ、どうしてくれるんですか
事前に案内なりなんなりしないとダメじゃないですか?
NAO
公式のヘルプ手順に従い、すでに初期化してしまいました。
救いの手は差し伸べられますか?
Srinivas4434
When it will be resolved chromecast issue
ozymandias45
imaginez le même problème sur les détecteurs de fumée connecté , en 5 jours , une hécatombe .Petite pensée pour ceux qui utilise ce materiel dans le cadre de leur boulot ..5 jours et ben !
marcogonfa
Hello please let me know when my chromecast can be fix
Kelly11
Restaurei o meu para configuração de fábrica e agora o que devo fazer? Não consigo configurar novamente.
IK4
If you change your phone date and time to when your chrome casts last worked then go on google home and re add your chrome casts, follow the set up on your device , then it will be ready for googles update, it worked for me
Jules79
This information should have come up in the google home app so we didn’t run through the usual troubleshooting steps and do the factory reset!
甲藤
設定していたスクリーンセーバーや時刻は表示されてますが、動画のキャストが出来ない。
見れなくなってから、対処方法を検索すると、コンセントやHDMIを差し直すとか諸々してしまってます。
DianaTamez
Deberían tener una manera más efectiva de avisar que está fallando ya que muchos al ver que estaban fallando los chromecast lo primero que hicimos fue reiniciar el dispositivo y ahora resulta que no debimos hacer eso  🫠
