GoogleNestTeam
Community Manager (Admin)
Update 3/20/25
Update 3/17/25:
Update 3/14/25:
Update 3/13/25:
Update 3/11/25:
Hi all,
Thank you.
Thank you for your patience.
GoogleNestTeam
16,161 REPLIES 16,161
GloriaSalm
Has this been solved? As we are still unable to use the Chrome cast. Thanks
Reading is your friend. See the status update pinned at the top of this page.
Pinkielee15
I use my chrome cast everyday it's depressing me it's not connecting my Android haven authentication problems plz fix asap plz
mccririck
Can you hurry up and fix this? Why is it taking you so long?
Mikijojo
Vi stoler på, takk.
IvyRom
You send this recomendación on Monday, we did it on Sunday due to your manual says that one solution is perform factory reset. ITS ABSURD
Annmel
Jag har redan fabriks inställt. Så jag hoppas att ni ändå kan åtgärda felet
Kalyanram
I reset my Chromecast. Pl let us know once the issue is resolved in mai id  #
Rball69
Are you sending out emails for corrective steps for 2nd gen chromecast users who factory reset before we were told not to? My issue is unable to authenticate during setup and/or adding knew device.
Correos electrónicos? como pueden conocer el correo electrónico?
Przemek1990
All time - „something went wrong„
Bodil1
Since yesterday (13/03) I have the same problem with my in-build caster in Android-TV. I've updated the app and checked the settings. Google home indicates "off-line".
Annoyed89
I did factory reset mine but I was able to get it back online thanks to another users comment. However, I still can't use it and it's telling me it's connected to a different wifi network, which it's not. When do you plan on having this fixed? Would have been nice to receive an email sooner than 4 days after the original problem.
Just leave it powered on and connected to the internet. The firmware update that Google started rolling out yesterday will fix this. Could take several days for it to hit your Chromecast.
Vansilva
Ainda não voltou a funcionar  o meu dispositivo.
Daisilva8
I reseted my device, and I can't connect again
Vansilva
Não está conectando
Anonymous
Not applicable
Bricking million devices, taking four days to inform customers, no timeline for a real fix. Adding a useless Youtube-Startpage that i cannot turn off and that takes forever to load. The YT-Startpage has timing problems, sometimes the equally useless sidebar appears right in a commercial and freezes the commercial in an endless loop. Sometimes it takes tens of tries to successfully cast Youtube.
Google, you made this device work less and less reliable over the years. This "issue" was badly handled and shouldn't have happened anyways. I will NEVER ever buy Google or Nest hardware, next time i'm buying European.
Better off going Chinese, buy parts for cheap (if they're still selling to where you are lol) and make your own. Personally going to go as F/LOSS as possible, DIY,  move everything to Home Assistant
martinpires5778
Hola si al ver qué durante días no he podido lograr que funciones el dispositivo tuve que resetear de fábrica y aún así no me ha funcionado más 😭
Work4Cheese
What if I already factory Reset my device before these messages? I have two chromecast devices currently not working.....
Kriss59600
Bonjour,
Moi bien sûr voyant que plus rien ne fonctionnait je l'ai réinitialisé usine..... Euh .... 3 ou 4 fois 🤦🏼 et pareil pour celui de mon fils ..... C'est seulement après que j'ai vu que c'était une panne générale.
J'espère que je saurai les faire refonctionner sans m'arracher la moitié de mes cheveux 😁
Joeri43
Enig idee hoe lang deze problemen nog gaan duren ?
Thayssa
Legal. Já vamos pro 5°dia sem solução.  Minha TV é só decoração nesses dias. Obrigada Google!
joskaatee
Ik heb 5 dagen geleden al een factor reset gedaan, omdat ik van niks wist
how does one know the firmware is updated to you
Bodil1
I checked the app in play store.
birrael74
Demasiado tiempo para subir una actualización.  no sé puede poner una actualización anterior????
mediamandan
So is there nothing a user can do to initiate the update? What do you mean by connected? Google Home can't currently see/connect to any of my 3 devices.
"Connected" meaning connected to your Wi-Fi network / the internet, so that they will be able to receive the upcoming firmware update fix. If you haven't done a factory reset, then your devices should still be connected to your Wi-Fi network (even though Google Home incorrectly shows them as being offline).
AdityaGupta
Please fix this ASAP, it's impacting many users and issue persistence for so long is not acceptable by any customer from any good brand like Google.
IdaMell
Om man redan gjort en återställning???
