GoogleNestTeam
Community Manager (Admin)
Update 3/20/25
Update 3/17/25:
Update 3/14/25:
Update 3/13/25:
Update 3/11/25:
Hi all,
Thank you.
Thank you for your patience.
GoogleNestTeam
16,162 REPLIES 16,162
Fix1
Because I followed the troubleshoot instructions in the first place and did a factory reset I have to wait longer for the update? Wow, good job Google. Now I am even more sure I am not buying a Google Nest/Home in the future.
BrunaFranciozi
No caso eu redefini o meu para a configuração de fábrica, vou ter que esperar até quando?
Gergana
You probably expect us to buy your new device for 130 euros. It won't happen.we can go on with our lives without your gadgets!
Jchat
Still not workinh for me
JessicaRollan
Si, lo restableci con configuración de fabrica a las 3 hs q dejo de funcionar...
Podrían guiarme para poder resolverlo y que vuelva a funcionar, por favor.
Gracias
M41c0
Eu resetei, agora backups logo!
markomontagne
Hi. My gen 2 devices that were not reset are now working again. My gen 1 devices that were not reset are not working. My gen 2 devices that were reset are not working. What updates are planned for gen 1 and also reset gen 2 devices? Thanks.
Campoggi
Y que hacemos los que hemos reseteado?
Por favor! Una semana es demasiado
gracias
Shadow15
I can now cast but my chromecast can't be detected by Google Home. Any thoughts?
MEichholtz
Jammer dat jullie zo laat zijn gekomen met deze info over het niet mogen terug zetten naar fabrieksinstellingen nu heb ik dus een chromecast zonder update en dus nog steeds niet bruikbaar. Gaat hier nog een oplossing voor komen of kan ik 'm zo weggooien.
Anonymous
Not applicable
Im back and working for past 2 hours thank you. I had factory reset but then rewound date by a few days and reconnected as suggested so all good now. Hope everyone else getting reconnected.
Caryngifford
I factory reset my devices
Gwada
Please fix it i need to watch formula one tomorrow at 6am my subscribe it's just for it and that sport thank you
IsaG
What happens if I reset it? Hopefully you resolve the problem . Let us know how to fix issue to those who RESET it! Thank you!
Lizardk21
Put your phone whit date march 05 , not automático date, then install tour Chromecast, let Chromecast update AND restart .
Zenilda5020
Como resolver o problema do Chromecast sendo que eu reiniciei
Moisito86
Y? Para cuándo? Tiro el aparato o que?
Car02
Yo lo que hice fue poner mi iPad (que es lo que uso para transmitir todo a la tv) con la fecha del viernes pasado, y ahi me dejo actualizarlo y todo... después tienes que volver a poner la fecha actual y listo!
Lizardk21
To all , I just reset.my Chromecast succesfully , just put on my phone a date before march 7,  like march 5. AND then install the cromecast , update AND after update , start whit no problem, you can restart 1 or 2 times AND works.
Yo tenía mi Chromecast inactivo porque lo inicie de fabrica, puse el teléfono a una fecha anterior 05 de marzo e hice la instalación normal, se instaló se actualizo y luego de reiniciar una o 2 veces quedó sincronizado. Luego cambie la hora de nuevo abrí una aplicación y comprobé que se sincronice
LeoLima
Preciso da configuração pra quem resetou o cromecast urgente😭😭
Preciso de ajuda porque eu resetei o meu Chromecast
Nasimghosheh
When it will be fxed
Nasimghosheh
It took long time
Samave1977
acabo de actualizar el Chromecast poniendo en l fecha del móvil el di 8 marzo y volviendo a instalarlo y ha ido ok. Gracias por la ayuda
edugaray
Please let me know
josemanuelmaria
Se supone q sois los mejores o tenéis a los mejores no veo ese trabajo en resolver este grandísimo fallo y siguen pasando los días y no hay respuesta ni solución grandísima empresa resolutiva
Magaagonzalez
Hola mi chromecast sigue sin funcionar yo lo restablecí de fabrica cuando había dejado de funcionar
El mio ya funciona! y estaba restablecido de fabrica... decime y te ayudo
kikagmiranda
E o tempo está passando e nenhuma resposta pelo ocorrido, por favor, nos ajude! Precisamos de pelo menos, um esclarecimento.
Robypro
Ya se está actualizando y funciona de nuevo, gracias
Mayara1
Eu restaurei
Mayara1
Não estou conseguindo acesso não acha o wifi aparece uma mensagem pra falar no suporte desde domingo passado.
