GoogleNestTeam
Community Manager (Admin)
Update 3/20/25
Update 3/17/25:
Update 3/14/25:
Update 3/13/25:
Update 3/11/25:
Hi all,
Thank you.
Thank you for your patience.
GoogleNestTeam
16,151 REPLIES 16,151
LmarC
Too late, I already did the factory reset. What the hell happened? Why did you ruin a perfectly working product? I hope you fix it soon and share your solution.
It's not too late. If you performed a factory reset during your initial troubleshooting, just do this:
https://www.googlenestcommunity.com/t5/Streaming/Regarding-an-issue-with-Chromecast-2nd-gen-and-Chro
Josshua
Cómo el ago para regalo ya que lo tenise de fábrica
**  If you performed a factory reset during your initial troubleshooting, you'll need to do this:
LeanDon
Para cuando una solución?? Tengo de 2° generación y todavía no puedo usarlo.
-> If you performed a factory reset during your initial troubleshooting, you'll need to do this:
sclronda
1 semana sem TV devido ao problema no Chrome e ninguém da uma solução ou alternativa
avaniaarya21
Chrome cast not working, I did factory set up also, all in vain, please help
***** If you performed a factory reset during your initial troubleshooting, you'll need to do this:
Ete632
Hola buenas quiero comentar lo que yo intenté y me funcionó, al menos para mí cromcast. Puse mi dispositivo ( celular ) con fecha del 07/03 ; osea configure mi dispositivo con esa fecha, acto seguido descargué nuevamente la aplicación home y me tomo esa fecha y lo pude actualizar
RintuGohain
Please fix it asap, our entertainment hub totally shut down, our whole family rely on it only.
Jhoyce
Não consigo conectar a nenhum disponível
Lalacici10
I'm aware you are trying to fix the Chromecast 2nd, but it better happen. Calling attention bc the roll out that happened definitely has caused an issue in my house. We use Google for most of our series and devices and would hate to turn everything off and become an apple family. So find the solution asap.
It has already been implemented (the fix), you have to make sure you are connected to the (right) Google account  so they can send the fix
Hissien
When install chromecast in tv appearances code and don't connect with mobile and ask to go to Chromecast.com /help
Please how to solve this problem??
Hello, change the date on your phone to a date before 03/08/2025, so you will be able to set up the Chromecast.
Hi everynody!
It is working!
I have changed the date in my phone to have march 1, then I open Google Home and it connected to Chromecast. I conffigued it whit my WiFi code sucessfully.
After that, I set automatic date in my phone and every works OK.
Alan17
Por favor passem alguma informação de quando vai voltar a funcionar porque e um absurdo,faz uma semana já sem funcionar.Tenho dois aparelhos e está sem funcionar os dois...paguei caro nos aparelhos e não estou podendo utilizar.
Faz um comunicado informando quando isso vai voltar por que dizer que está trabalhando é muito fácil...uma semana já que estão trabalhando e nada.
AbeniGiancarlo
Salve, purtroppo ho premuto il pulsante per il ripristino dei parametri di fabbrica, non si collega più
Anonymous
Not applicable
Idem. Stanno lavorando ad una soluzione. Speriamo risolvano presto. ✌🏻
Eu também
su alcuni siti che hanno parlato del problema  di Chromecast dicono che i tecnici Google hanno risolto il problema del bug ma io continuo a non riuscire ad reinstallarlo.Comunque il fatto che evidenziato il problema il reset del dongle Chromecast non andava assolutamente effettuato l'ho appreso da Tom's Hardware e non da google che,dice,lo ha comunicato agli utenti con una mail io mai ricevuta dal giorno 9 marzo cioè da quando si è verificato il problema.
sourabh-dosi
Hi, I have performed a factory reset on my Google Chromecast, but I'm experiencing connection issues. What are the steps to fix this so my device can properly connect? I would like to raise a complaint regarding this matter
I can't help with your complaint, but this will fix your Chromecast:
Aiza1
Its been 5 days now i cant cast on my Tv.. How many times i already put on and off my chromecast its say couls not authenticate..I even make a new account on gmail and still the same feedback..keep going back to google help.. Etc..pls help..
If you performed a factory reset during your initial troubleshooting, you'll need to do this...
Dai1
Lo restablecí de fabrica.  Como hago ahora ?
dayanerun
Quando vão arrumar???
Eliza2
I'm not able to connect my android to tv
Ya intenté de todo y no se resuelve
Si logras resolver ese detalle me comparte su solución por favor
Nalga
Quiero conectar el chom a mi tv
EduardoN
Hi @Eliza2,
Thank you for contacting our community support team! I completely understand the inconvenience you're experiencing because you're unable to connect your Android device to your TV, and I appreciate you taking the time to share this information.
Based on this information, I'd like to ask you a few more questions about this concern. I'm here to help!
  • When did the issue first occur?
  • What is the model of your device?
  • Could you send us a photo of this device?
  • Do you see any error codes when you tried to connect this device?
  • What app were you using when you tried to connect it?
Please feel free to share any additional details you think might be relevant.
Eduardo
EduardoN
Hi there @Nalga and @JuanCarlos,
Thank you for reaching out to our support community! I understand this situation that you're experiecing and I appreciate you taking the time to troubleshoot your device.
Based on this inconvinience, I'd like to ask you questions for more . I'm here to assist you further!
  • What type of Nest Thermostat do you have?
  • Do you have any messages in your thermostat?
Eduardo
Eliza2
Last Sunday, I was trying to cast from my phone to the TV but couldn't find the option, so I rebooted the Chromecast. After that, I couldn't connect at all. My phone's a HUAWEI P30, and the Chromecast is pretty old, so I’m not sure what model it is.
Luis_prietto
Para reinstalar o chomecast após o problema de domingo dia 9, quando restauramos as configurações de fábrica, troque a data do celular para dia 8 ou antes, e resete novamente o chromecast, e as atualizações serão instaladas automaticamente.  Tem que enganar o certificado que teria vencido dia 9.
Obrigado cara, deu certo aqui.
