GoogleNestTeam
Community Manager (Admin)
Update 3/20/25
Update 3/17/25:
Update 3/14/25:
Update 3/13/25:
Update 3/11/25:
Hi all,
Thank you.
Thank you for your patience.
GoogleNestTeam
16,160 REPLIES 16,160
If you performed a factory reset during your initial troubleshooting, you'll need to do this procedure to be able to receive the update:
https://www.googlenestcommunity.com/t5/Streaming/Regarding-an-issue-with-Chromecast-2nd-gen-and-Chro
¡Lo solucioné! Intenta cambiar la fecha del teléfono que usas para configurar tu Chromecast. Cualquier fecha anterior al 9 de marzo y luego intenta configurarlo de nuevo. Se conectará y actualizará tu Chromecast.
PluggedIn
Seriously, the fact that it’s taking so long to fix is insulting.
Google started rolling at a firmware update fix on Thursday.
However, if you performed a factory reset during your initial troubleshooting, you'll need to do this procedure to be able to receive the update:
GlennFeit
The fix came through for the one Chromecast Audio device that was not factory reset.
I was able to fix the two remaining Chromecast Audio devices!
By manually adjusting the date on my phone to the day before the Chromecast's security certificate expiration date (March 9, 2025, the root cause of the problem) I was able to set them up, allowing the firmware fix from Google to install.
All of the (3) Chromecast Audio devices are now operating beautifully!
Oh my god, I can’t thank you enough! I was able to get my chromecast up and running by adjusting the date on my phone like you mentioned. I was seriously about to call it and get another product but gave it another go after reading your comment & my jaw dropped when it actually worked. Thank you thank you thank you!
ahmedaboulenein
Factory Reset Chromecast Fix
I did factory reset to my Chromecast 2nd generation and was able to fix it in a few minutes after understanding the root cause of the problem is the Chromecast device certificate expired. It's a very simple trick and I used and old phone to avoid any issue on my primary phone. The Chromecast certificate expired on March 9th, when you try to set up the device, the issue is Google Home app is not able to connect to the device because it figures its certificate has expired and the connection is not secured so it refuses to connect.
Fix:
  1. Go to date and time settings in your phone,.
  2. Disable the auto update from the network.
  3. Change the date to anytime before the expiry, March 9th, I set it to February 14th to be safe.
  4. Just do the normal device setup from Google Home App, it will be able to connect to the device because from the phone perspective (and Google Home App) the certificate is now valid and didn't expire yet 😂
  5. Once you complete the setup, it will automatically pull the latest build which contains the fix Google is rolling out.
  6. Your Chromecast is back working as normal, Congrats.
  7. Oh, change your phone settings back to auto update from the network.
Any time! ( Disclaimer - I work for Amazon 😎
Yes, that's the fix.
One error: the security certificate actually expired on March 9th, not March 12th as you stated. So you should temporarily set your phone's date to March 8th or earlier.
Thanks for the correction on the date, I went to the previous month to be safe 😁
rafael44flecha
Como vou saber quando estiver funcionando novamente?
If you performed a factory reset during your initial troubleshooting, you'll need to do this procedure to be able to receive the update/fix:
Walidkanne
I have already performed reset during initial troubleshooting and I still have an issue. So please, help me to resolve this issue.
Thank you very much.
-->If you performed a factory reset during your initial troubleshooting, you'll need to do this:
Cristiancchr01
Para cuando señores ya paso demaciado tiempo y compramos un producto que no se puede usar, urge respuesta o reembolsos
--> Google started rolling at a firmware update fix on Thursday.
johnnyzero2
For all the people who performed a factory reset during their initial troubleshooting, this procedure will allow you to reconnect your Chromecast to your Wi-Fi network, so that it can receive the firmware update fix that Google started rolling out on 3/13.
1) Temporarily set the date on your smartphone (or tablet) to March 7, 2025 or earlier. If you don't know how to do that, see below.*
2) Use the Google Home app to re-setup your Chromecast by adding it as a new device (+). You still won't be able to cast, and the device will be grayed out in the Home app, but that's ok. Most importantly, it'll now be reconnected to your Wi-Fi network so that it can receive the firmware update fix.
3) Change your phone's date/time setting back to Auto now.
4) Sit back and wait for the firmware update from Google to be installed. This should restore your Chromecast to full functionality.
Note: Supposedly it's being done as a "phased rollout", so it could take a while for the firmware update to hit your Chromecast. Also, some have reported that power-cycling your Chromecast (unplug/re-plug the power cable) will sort of "provoke" the firmware update to be installed. Patience.
*How to change your phone's date/time settings:
For iPhone/iPad: go to Settings, General, Date & Time. Disable "Auto" and manually set the date to March 7, 2025 or earlier.
For most Android phones/tablets: Settings, General Management, Date and Time. Disable "Auto" and manually set the date to March 7, 2025 or earlier.
**Google REALLY should pin this information to the top of this page.**
Remo86
Am unable to connect Chromecast device. When it will be fixed.
shielo
Can you help me my google chrome device not working on my tv. How do i fix it
Vishal130
How long we will be waiting for this issue to be resolved, team can you please go ahead and resolve this issue as soon as possible
もりまさ
まだキャスト出来ません。インターネット接続が出来ません
Sonodanobuo1928
O problema é uma empresa como o Google deixar milhões de usuários sem poder acessar os conteúdos através  do Chromecast é uma verdadeira palhaçada o que esta empresa está fazendo com seus consumidores pelo mundo inteiro,
Neajal
How Long you can fix it ?
chrispher1
I still cant use Google Chromecast.
Are there any fix on this issue?
Gajanan1
Its not working for me. For how long we should turn on the tv before it starts downloading the update.
Amitoj
Finally i got the update for my chromecast 2nd gen, its working fine now
Anonymous
Not applicable
Woher? Wo kann man es herunterladen?
Revhead2u
I’ve got it back!
set your phone time  to 7th February , then restart everything and then set up
chromecast.  Then once set up put phone back to today’s date. I can’t believe it but t it worked. Yes I too reset the Chromecast when t wasn’t working. Tried hundreds of times to set it up but it didn’t work then tried this.
too easy , problem over thank goodness
Hassank9966
Juliaandco
I have been having this issue longer than than just the last week and it seems there are no dates on this? Am I not ever able to use these speakers again ?
Shevøck
Google the fix for factory-reset devices; it's easy!
On your setup device: turn off auto-date, set the date to March 5, and you can easily connect to the Chromecast and let it update!
my iPhone won’t let me do that 😞
KiwiChef
This is terrible. 4 days without use
SunilMahato
What is the eta? By when this can be resolved?
Kapil15bhargava
When hit will be fixed ??? Someone can fix the timeline…
this is really a sad part from google side… if Google can’t fix a problem.. then who else??
redneckprincess
Now the problem Is that we were told to reset to factory to fix the problem in the beginning and now we’re screwed. How long is this fix going to take?
Raghavasai
I had ordered for anew chromecaster online, shall I cancell the order or you fix the existing gdevice
The new device is to be delivered soon, please enlighten me for cancelation
Us2
Thank you
Fabietto71
Purtroppo ho resettato più volte il mio device, perché avevo problemi di linguaggio e ancora adesso li ho
