Update 3/20/25
Update 3/17/25:
Update 3/14/25:
Update 3/13/25:
Update 3/11/25:
Hi all,
Thank you.
Thank you for your patience.
03-20-2025 10:49 AM
03-16-2025 02:39 AM
No wonder my tv just disconnected out of nowhere like I’ve been trying to reconnect it and I did factory reset it bc i thought that was the issue
03-16-2025 02:41 AM
Estou ha dias sem poder assistir minha tv, pois utilizo o chromecast para visualizar todos meus aplicativos de streaming, como globoplay, netflix, disney, youtube, etc… não posso sequer assistir a tv fechada, pois tendo o chrome cast , não tenho antenas instaladas!!!! Ressetei o aparelho e estou aguardando instruções para a regularização! Espero sinceramente não precisar tomar medidas juridicas!!!!!! Obrigado, meu nome é Sara nunes de Oliveira , celular 5541996814191
03-16-2025 02:41 AM
If factory rest done how to fix this
03-16-2025 05:17 AM
Try to update your device date to 1st March 2025 and then connect chromecast to get updated.it will be working after taking time to update.
03-16-2025 02:47 AM
As my chromecast stopped working, I had to buy a google streamer device and it worked for a day or two. Now the tv screen is losing the picture. I suppose it’s the same problem with the chromecast. Gee, fix this quick!
03-16-2025 02:55 AM
I have already done a factory reset on the chromecast, what to do now?
03-16-2025 02:57 AM
I had already reset my device and tried to remove and reinstall to my home network prior to this announcement. I hope there will be instructions provided for this this scenario as well.
03-16-2025 03:00 AM
Workaround: Change Date on smartphone to a date earlier than 6th of March, then add chromecast in your Home app. That made my Chromecast work again 🎉
03-16-2025 04:00 AM
How can you physically change the date on an iPhone ?it’s an automatic thing isn’t it?
03-16-2025 04:28 AM
Deactivate ‘Set date autmatically’ in General settings on you device. Then you can set to a specific date yourself. Both for Android and iPhone.
03-16-2025 03:01 AM
The first thing you do, when the cromecast went down, is to reset. So please give instructions how to resolve that problem, so that we can watch tv again. And hurry!!!
03-16-2025 03:00 AM
03-16-2025 03:57 AM
change phone date to any day in Feb and set it up again. it should work.
03-16-2025 03:06 AM
I'm hoping Google can resolve 'cause I set a factoring reset a week ago
03-16-2025 03:07 AM
I am having problem with the device it is not working properly. Need help
03-16-2025 03:18 AM
Hi GN Team!
Thanks for solving the issue with chromecast 2nd gen. rather quickly. Now on Sunday one week after the issue appered chromecasting works fine here. As many others I tried to factory reset it but fortunately didnt quite succeed with it.
Hopefully we are gonna enjoy your best streaming device so far for many years further on 😉
Magnus, Gothenburg, Sweden
03-16-2025 03:19 AM
I had no update on my Chromecast issue
03-16-2025 03:19 AM
Tol late, factory reset was ewpected to sonve the issue. What to do now?
03-16-2025 03:24 AM
Facing the chromcast 2 breakdown, I reset the factory config.
It does'nt solve anything, and the tentative to fix it does'nt work. Any issue to propose?
03-16-2025 05:59 AM
Yes, the answer is here in this thread.
03-16-2025 03:21 AM
One week to solve a problem?, i reset the chromecast audio and now?
03-16-2025 03:35 AM
Ainda não consigo conectar. Quando solucionarão o problema?
03-16-2025 03:39 AM
Hi community
Any solved résolution for people as me who perform a factory reset ?
Thanks
Regards
03-16-2025 03:46 AM
yes change time on phone to any day on Feb will make setup work
03-16-2025 03:49 AM
changing the date on your phone to 7th March (or prior) and setting up a Chromecast that got factory reset works.... I tried and IT WORKED!!!!!!
03-16-2025 03:46 AM
Ok, quedo a la espera de la solución
03-16-2025 03:48 AM
Please fix this issue 😞 as I face this since 2 weeks my kids can't YouTube for there shows and they blame me for this
03-16-2025 03:49 AM
03-16-2025 03:48 AM
Factory reset? Changed date on your phone and setup.
Someone commented (sorry brothers, unable to track that angel's comment now that changing the date on your phone to 7th March (or prior) and setting up a Chromecast that got factory reset works.... I tried and IT WORKED!!!!!!
If that person sees this, Thank you!!
@GoogleNestTeam reward him.
03-16-2025 03:49 AM
You need to change the date on your phone to before the 7th. Go to Google home and re set up your Chromecast. It will pick up the new fix. Change your date back
03-16-2025 03:57 AM
When you say change the date wat you mean in the settings?
03-16-2025 04:16 AM
Go to settings - generally - date and time - turn of automatic time - set a time fx 1. mars. And then use your google home app. and add your cromecast again. On your TV you will se that it is making a update. Wait until it+s finished, and it should then be okay.
03-16-2025 03:48 AM
O meu que não resetei está funcionando mas o que resetei no dia do problema não voltou com a atualização de reparo
03-16-2025 03:49 AM
Please provide setup for relaunch this chrome cast 2nd generation as I already factory 🏭 reset it
03-16-2025 03:53 AM
Hey I did factory reset mine it’s still not working how long will this take please?
03-16-2025 04:34 AM
See my last post
03-16-2025 05:57 AM
Until you read the answer in this thread and help yourself.
03-16-2025 03:54 AM
Non funziona...
03-16-2025 04:00 AM
When will the fix for the devices that were reset be done? Wish this notice had been put up as soon as it was made aware.
03-16-2025 04:03 AM
I had reset my device because I didn't know the issue and thought something was wrong with the WiFi etc. I have trouble to connect now, when will we get updates about people who reset it ?????
