Update 3/20/25
Update 3/17/25:
Update 3/14/25:
Update 3/13/25:
Update 3/11/25:
Hi all,
Thank you.
Thank you for your patience.
03-20-2025 10:49 AM
03-16-2025 04:43 PM
Chromecast 2nd gen . I've already done the factory reset when the issue began. How I'll be notified when a solution appears? Thanks
03-16-2025 04:44 PM - edited 03-16-2025 05:02 PM
(Possible) NewsFlash:
Some users have reported here that Google has just released a new version of the Home app (currently for iPhone only?) that addresses the "factory reset" hellscape that many are experiencing. I can see that there is a new version on the Apple App Store from today 3/16, but I'm an Android guy so I can't confirm that it actually fixes this issue. That would be great, a much simpler solution than the well-known "date" workaround, especially for non-technical users. If true, then the answer would be as simple as updating to the latest version of the Home app and then using it to re-setup your Chromecast.
I'd like to hear from other iPhone users here if this is indeed the fix that so many people have been waiting for. Please report results here.
Also, if all of this is true, I assume they'll be releasing an Android version soon.
03-17-2025 06:39 AM
Hello.
Yes it works. I did from my iPad and I can configure the Chromecast
03-16-2025 04:43 PM
Olá o chromecast não está conectado no home
03-16-2025 04:45 PM
Antes de ver esse tópico já restaurei o meu chromecast 2ª gen, o que eu faço agora?
03-16-2025 04:47 PM
Yeah, I had factory reset mine before I knew it was a network-wide issue and not just a device hiccup. Oops 😞
03-16-2025 04:46 PM
Prezados, boa noite.
Há alguma resposta sobre este ocorrido. Até o presente momento continuo sem poder usar meu dispositivo. Afinal de contas, ficarei no prejuízo ou a Google irão corrigir ao que houve?
03-16-2025 04:48 PM
My Chromecast hasn't been functioning for a week now. I was told to reset the device but this failed. How do I reset!!!
03-16-2025 04:51 PM
I factory reset my device 😕
03-16-2025 04:52 PM
Meu Chromecast não está funcionando.
03-16-2025 04:55 PM
O Chromecast não funciona
03-16-2025 04:57 PM - edited 03-16-2025 05:12 PM
There is a fix if you factory reset it. I saw it on techradar.com
You have to reset date to March the 8th on your phone (before certificate expired), add the device again in Google home and it then it will do the update. Change your phone date back to auto date and time (very important) and Chromecast is now working fine. Thanks Stephen B and Marina Cascais on Tech Radar
03-16-2025 05:01 PM
Tell everybody to click on the link for johnnyzero2 Reply. It works!
03-16-2025 05:01 PM
Eu resetei e restaurei a configuração de fábrica não sabia que não podia... E agora o que eu faço?
03-16-2025 05:04 PM - edited 03-16-2025 05:40 PM
(possible) NewsFlash:
A few users have reported here that Google has supposedly released a new version of the Home app (currently for iPhone only?) that addresses the "factory reset" catch-22 hellscape that so many are experiencing. I can see that there is a new version on the Apple App Store from today 3/16, but I'm an Android guy so I can't confirm that it actually fixes this issue (and the changelog isn't specific about exactly which bugs/ improvements it addresses). If true, this will be a much simpler solution than the well-known "date" workaround, especially for non-technical users. The solution would be as simple as updating to the latest version of the Home app and then using it to re-setup your Chromecast.
Of course, if all of this is true, I assume they'll also be releasing an Android version soon.
03-16-2025 06:04 PM
There's a fix in for Android users if factory reset Chromecast.
03-16-2025 06:09 PM
03-16-2025 06:11 PM - edited 03-16-2025 06:26 PM
Thanks. Yes, I'm well aware of that fix.
I've been posting my own version of those instructions everywhere I can for the past several days:
btw, that same fix will also work for iPhone users, assuming their date/time setting isn't stupidly locked down by their cell phone carrier. Only a few carriers do this.
03-16-2025 06:09 PM
03-16-2025 05:04 PM
Eu acho que o Google está c... Para arrumar o bug, pois a intenção deles é fazer o pessoal ficar p... E trocar de dispositivo
03-16-2025 06:10 PM
03-16-2025 05:08 PM
Não consigo conectar o meu crome redefinir ele
03-16-2025 06:10 PM
03-16-2025 06:50 PM
>> If you performed a factory reset during your initial troubleshooting, you'll need to do this..
https://www.googlenestcommunity.com/t5/Streaming/Regarding-an-issue-with-Chromecast-2nd-gen-and-Chro
03-16-2025 05:12 PM
Annoyed..... my chromecast hasn't worked in a week! When will the issue be fixed?
03-16-2025 06:10 PM
03-16-2025 06:50 PM
>> If you performed a factory reset during your initial troubleshooting, you'll need to do this --
03-16-2025 05:16 PM
Me puede decir cómo configurarlo otra vez
03-16-2025 06:49 PM
>>> If you performed a factory reset during your initial troubleshooting, you'll need to do this....
03-16-2025 05:20 PM
Devido ao problema que aconteceu, restaurei o aparelho (Resetei), agora não consigo configurá-lo.
Como devo proceder?
03-16-2025 06:48 PM
03-16-2025 05:22 PM
Buenas como sabremos cuando se va a solucionar? Se nos puede enviar un comunicado o correo global, disculpen se lo que conlleva, pero estaría bueno eso y quizás más comodo, gracias.
03-16-2025 06:48 PM
--->> If you performed a factory reset during your initial troubleshooting, you'll need to do this..
03-16-2025 05:43 PM
When?
03-16-2025 06:47 PM
---> If you performed a factory reset during your initial troubleshooting, you'll need to do this..
03-16-2025 05:47 PM - edited 03-16-2025 06:06 PM
For all the people who performed a factory reset during their initial troubleshooting, this procedure will allow you to reconnect your Chromecast to your Wi-Fi network, so that it can receive the firmware update fix that Google started rolling out on 3/13.
1) Temporarily set the date on your smartphone (or tablet) to March 7, 2025 or earlier. If you don't know how to do that, see below.*
2) Use the Google Home app to re-setup your Chromecast by adding it as a new device (+). You still won't be able to cast, and the device will be grayed out in the Home app, but that's ok. Most importantly, it'll now be reconnected to your Wi-Fi network so that it can receive the firmware update fix.
3) Change your phone's date/time setting back to Auto now.
4) Sit back and wait for the firmware update from Google to be installed. This should restore your Chromecast to full functionality.
Note: Supposedly it's being done as a "phased rollout", so it could take a while for the firmware update to hit your Chromecast. Also, some have reported that power-cycling your Chromecast (unplug/re-plug the power cable) will sort of "provoke" the firmware update to be installed. Patience.
*How to change your phone's date/time settings:
For iPhone/iPad: go to Settings, General, Date & Time. Disable "Auto" and manually set the date to March 7, 2025 or earlier.
For most Android phones/tablets: Settings, General Management, Date and Time. Disable "Auto" and manually set the date to March 7, 2025 or earlier.
**Google REALLY should pin this information to the top of this page.**
03-16-2025 06:29 PM
Fantastic. Thanks for posting the solution/fix. I changed my cell phone date to 2/1/25 then went through the steps to add my 2nd gen Chromecast to my Home app. My Chromecast immediately began downloading updates. Afterwards change my cell phone back to auto-date. My Chromecast completed the update and boom, I can cast again. THANKS SO MUCH. Google should send this to everyone who has performed a factory reset.
03-16-2025 06:40 PM - edited 03-16-2025 06:41 PM
Olá! Eu fiz a redefinição de fábrica, acabei de fazer o que você postou aqui e deu certo, meu Chromecast já está funcionando! 👏🤘😉
03-16-2025 06:47 PM
>> If you performed a factory reset during your initial troubleshooting, you'll need to do this.....
03-16-2025 05:48 PM
Hi - how much longer till it's fixed?
