GoogleNestTeam
Community Manager (Admin)
Update 3/20/25
Update 3/17/25:
Update 3/14/25:
Update 3/13/25:
Update 3/11/25:
Hi all,
Thank you.
Thank you for your patience.
GoogleNestTeam
16,135 REPLIES 16,135
I did this too, I managed to re add it by changing the date on my phone to before march 9th and adding  it using the google home app. However streaming to the device is still not working
DannisvB
Work faster Google. We are waiting for a few days already.
Danipap
Ponen que no se regrese a los valores de fábrica, pero antes seguí cada paso de su centro de ayuda donde decía que debía restaurarlo. Ya quedé con el dispositivo desinstalado y sin funcionar. Por favor necesitamos solución rápido.
Jcs
What is taking so long to fix the issue of millions of chromecasts that stopped working on March 10. I have several in my household and I would like to know if I have to upgrade them or not.
Either fix the issue or notify your customers to upgrade......asap
Dib
Un problème qui dur des jours mes enfants ne peuvent même plus regarder la télé puisque sans ça nous n’avons rien c’est génial en plus ça bug comme ça du jour au lendemain alors que ça fais quand même 9ans qu’ont a notre appareil bref s’il vous plaît faite au plus vite merci
NestMitch
Do not factory reset your device.. oups..
Millionsofusers
A status update is no luxury
The Era of giant corporations, theybhave no more customers, we are nothing
JC_Lon
  1. Please inform us when this is fixed, I hope it doesn't take 3 months.
lukedawe
Hi I feel silly but my first instinct was to factory reset the chromecast! I would like to know where I go from here please 🙂
nowhere, just wait, more than 2000 questions here and they did not answer anyone
Cesard
Puedes cambiar la fecha de tu dispositivo, en mi caso el móvil al 6 de Marzo y así volver a recuperar la configuración previa volviendo a reinstalar Google Home e identificar tu dispositivo. Repito, en mi caso envío contenido desde mi móvil a mi TV no inteligente en la que tengo el Chromecast.
pero no puedes mirar streaming, nonsirve para nada
Mishonio
Any updates on the fix?
ccouto
What is googlenestteam? an official google department or something pirate? why 2000 questions in an official site have no answer from Google?
ripchromecast
third evening without the chromecast and just dead silence?
I will never purchase a google product again 🤡🤡🤡  🤡🤡🤡🤡🤡🤡🤡🤡🤡🤡🤡🤡🤡
neither use their browser
ccouto
I believe  Google put us in an empty room. We are alone talking to nobody
johnbutcheracad
Any news? Fixed? How do I'll be informed??
call chromecast support, here is a community without no one from google
Kbbbbbnn
When will it be fixed?
Chrisboz
Hi you've sold over 100 million of these devices!! When you launched Google TV you promised to keep Chromecasts updated!! Some promise!! When are you going to fix it? You promised to do so on Sunday!  Nothing's changed!
ShameOnUGogl
When will this **bleep** be fixed?
we are talking to each other, not with google
we do not know, we are alone in this room
tismai
'we are working on a fix'... does DOGE hit your service and made it so difficult to fix this ... 🙂
Matei
Please do it faster... 2 days without these devices is unserious... lost many customers... the mass media is informed.
Lulaina
Has anyone from Google provided any update on this?
MagG
Only what's been pined on the top of this post
laughs,no, they redirected us to this empty room.
Kayloosh
How will we know when the issue is resolved?
call the chromecast support , we had being redirected to this empty room, laughs, they are genious
telmcgraw
When will we get an update?
not here, they redirected us to an empty room, need to call google nest customer support,  to receive an email when they fix it
FAOD
Stop this **bleep** show and fix it! Can’t cast anything and it’s very rude of you to not notify us what the cause and when it is expected to be fixed! 0/10 🤬
even worst, they redirect you to an empty room, you are not talking to google
Fer3
Yo lo reinicie para volverlo a configurar y cuando se está terminado de configurar me sale que active la red local, la cual si está activada, y de ahí no paso.
Cloudtwister
The decline of Google software unfortunately continues.
Breaking all of the V2 Chromesticks is one heck of a reputation trasher.
It's now day 3 and still no fix.
This issue also revealed that Google are dropping tech support for Chromecasts. And the replacement is £99...
I'm looking into switching to Apple TV.
UKchromecast
Another affected customer here in the UK 😕. Please fix...
Also did the factory reset then read that we're not supposed to do it. Cone on Google, support your customers. I remember when you were a fantastic innovative company who had a great attitude to your customers rather than trying to extract every penny by removing updates/ support to force people into replacing hardware which still works fine. That is until you make it redundant!
Please fix this, look at how many people you are p*ssing off
