GoogleNestTeam
Community Manager (Admin)
Update 3/20/25
Update 3/17/25:
Update 3/14/25:
Update 3/13/25:
Update 3/11/25:
Hi all,
Thank you.
Thank you for your patience.
GoogleNestTeam
16,122 REPLIES 16,122
Agree!
I knew something was odd when 2 of 4 Chromecasts went down...
I thought it was my WiFi/internet connection that broke …. Then I factory resetted one and go in that “I need to change the date of my phone to earlier “ because I did say early on on Reddit “10$ it’s an expired SSL certificate” 😉
すみ
型番が古いせいかと思い込んでいたよ!
そっち側の問題だったとは💥💥
Actually, I got here from doing a search in [competing search engine] after several full runs through the troubleshooting guide produced no results. It’s not exactly down a dark set of stairs behind a BEWARE OF LEOPARD sign, but this forum wasn’t obvious.
Unfortunately many of us have already reset the device because that's what we would do if we were having trouble and they do have to be reset sometimes
I have been having to reset mine on a weekly basis. The issues with this 2nd Generation device are constant. My 1st Generation device, on the other hand, still works splendidly.
I just force my time on my phone back to Jan 1st 2025 and was able to setup and configure the Chromecast. It did get an update as soon as it connected, now it's connected back to my network and added in Home. I changed my time back, and can now cast.
Salve, purtroppo ho fatto il reset con interruttore. Sono certo che riuscirete a ripristinare la funzionalità del mio dispositivo. In attesa di sollecita risposta porgo distinti saluti
Si, te dicen un día después que no reinicies cuando la ayuda te lo recomienda
Spellbounding
I found my old 1st gen chromecast & it works..it says its offline,but it still streams or mirrors devices..weird
Seems like all this started around same time US got hacked from areas of Europe. Specifically X.. i wonder if its a coincidence or Coquinkadink
Ya puedo reiniciar?
Potverdorie helpcentrum zei vandaag  12 maart om mijn chromecast terug te zetten naar de fabrieksinstellingen nu wordt er gezegd niet doen ??? @@WTFGOOGLE
Tout à fait
3 jours que je tente de faire communiquer mon chromcast avec homme et rien à faire ... pourtant home reconnaît mon chromecast et se connecte à lui mais pas de retour de chromecast
Là il nous est indiqué de réinitialiser les paramètres usine ... ce que je fais depuis 3 jours ... et seulement là je viens de voir la notification et lire le message...
I already reset factory.
What do i do now?
Åsaåsa
Me too…
I tried 10 times
Doesn't work still says Google home app can't communicate to Chromecast
I have reset it how mean time😡
Pls help to improve my phone device thank you
Thank you to your support
Infatti io l’ho resettato. Ho scoperto solo dopo che non potevo farlo
 Salam
Exactly what I did aswell still not fixed and still won't communicate with my devices
Yes, that is right, I did it, too 😳
merci ! nous sommes impatients
Pour ceux qui comme moi avaient tout tenté y compris une réinitialisation usine en rendant du coup leur chromecast indétectable, il suffit de procéder comme suit :
- à partir de l'appareil recevant la musique (iPhone, androïd, tablette..) : aller dans « Paramètres » -> « Date et heure » -> désactiver le réglage automatique -> choisir n'importe quel jour antérieur au 9 mars (date butoir péremption SSL responsable du problème)
- puis lancez Google home et installez le chromecast. Il sera de nouveau détecté. (Ça a marché pour moi)
Mais attention, il sera juste de nouveau prêt à recevoir le correctif lorsque Google aura fini..
Merci à GoogleNest
Emusk
Have you tried turning it off and on?
AndresLV
hahahah thanks to The IT Guys
JJ-27
@Emusk, oui et comme tout le monde j'ai tout essayé avant de procéder comme je l'ai expliqué. Mon Chromecast est donc à nouveau détecté (il ne l'était plus après la réinitialisation d'usine) et prêt à recevoir le patch lorsqu'il sera lancé par Google.
Yokozuna
Tu sais pas par hasard si cela va être fait rapidement  « Le fameux patch » ?
JJ-27
@Yokozuna Non, mais j’ai confiance
BasilBox
never trust someone with the username “Emusk”
Mary64
Anonymous
Not applicable
Gracias por esa idea. He hecho lo mismo y, aunque no puedo enviar contenido aún al Chromecast, al menos vuelve a estar conectado a la wifi.
Acá igual, están los dos que tengo conectados al WiFi pero no puedo enviar contenido cuando les quede bien pueden mandar un fix de verdad si no les molesta
Amedee
Bonjour, il est vrai que l’on se sent un peu seuls devant ce problème !
Que alguien me diga q hago no puedo conectar el chromecast
Chartz
Bonjour,
Oui on voit à nouveau le Chromecast Audio si on revient au 8/03 mais il disparaît à nouveau lorsque la date est celle d’aujourd’hui. Donc ça ne marche pas.
I can see the Chromecast in Google Home when I change the date to, say, March 8th but it disappears again when I set back to today’s date. So the ‘fix’ isn’t one.
Estaremos aguardando instruções.
How will I know when a fix has been msgs for those of us who did a factory reset?
You just need to set your device that connects to your chromecast back in time.
I have put my Phone back to a date before the problem and in google home I added the chromecast again.
So now it's there again, can't stream but ready to reeive the update from google.
