GoogleNestTeam
Community Manager (Admin)
Update 3/20/25
Update 3/17/25:
Update 3/14/25:
Update 3/13/25:
Update 3/11/25:
Hi all,
Thank you.
Thank you for your patience.
GoogleNestTeam
16,160 REPLIES 16,160
Zyra
Same here! What is happening?
See this post.
It's not the final solution, but it might help you
Camelot1
Same here for the past 2days
Mariola21a
Will that be fix at all? I spent 3 days and 2 phones (android and iPhone) and tones of different apps to figure out what's going on. You should have better way of letting ppl know that problem is on your side. Had no clue about this website. Waisted 3 days and now know one can give us an ultimate time when problem will be resolved.
Bibi313
My Chromecast IS not working .Authentification failled.I Have reset wifi and Chromecast and still not working .This has happened to my 3 devices. At the same time .
Orange
Wow, I had to look twice to see if that was my post or not. I have had the identical thing happen. To my 3 devices also. Chromecast has worked fine for years!  'Why stop now?' , I wonder. I got to the stage of being able to download Google Home on one device, my phone (can't get it on 2 tablets, but haven't needed to before) The TV i want to cast to is called 'living room TV' but  when I click on that, it ends up saying that my chromecast 'couldn't be verified'
poz
any news yet?
FaisalJaved
I have factory reset the Google Chromecast 2nd Gen device and google home app identifies the Chromecast but it is not communicating with it. Kindly resolve asap
Amalric
Vous donnez l’indication trop tard. Quand on suit le processus de réparation en ligne, votre site suggère de rebooter le chromecast. Donc merci de nous apporter réparation ou dédommagement.
C’est un community forum… ton post sert à rien à part faire suer plein de membres de la communauté avec un post inutile réclamant un dédommagement… sérieux , ils vont sortir une mise à jour et une procédure pour récupéré les CC.  Un peu de patience bordel .
cellchris
This is good to  know - but I don't use Nest, and until this issue arose, I had never used Google Home.  As such, I did not get the message to not factory reset my second generation chrome cast device and am not sure how to get the message on how to fix the device I did factory reset.  I was directed to do so by the step by step trouble-shooting instructions published by Google.  Please help.  #
gmull70
Now you say don't factory reset but trouble shooting tells you to factory reset hmmmm
leokcla
Este mensaje fue del dia Lunes. Cuando vamos a tener finalmente nuestros equipos funcionando como corresponde?
Dennos una respuesta seria y concreta por favor.
Gracias
Carocas
Llegue tarde a esto. Lo reestableci. Y ahora? 🤦🏿‍♀️
Bollox88
I reset all my devices and then hours later got the email telling me there’s an issue and not to do a factory reset……well that wasn’t very fu€king helpful!!! Why wasn’t there a timely notice sent to everyone???? Not good service and customer support!!
Serenaike
you did not publish anything for hours and almost all peolple resetted the chromecast!
JR1980
Too late.
Resetting is the normal behaviour of a user.
Right after: "have you tried to turn it off and on again"
Please communicate the fix.
Laura1814
Yes but it does nothing and won’t connect
cellchris
This is good to know, but prior to this issue I had never used Google Home or Nest.  As such, I did not receive the message to not factory reset my second generation chrome cast device and actually followed step-by-step trouble-shooting instructions published by Google telling me to perform a factory reset.  My concern is that I will miss instructions on how to fix the factory reset device, and also miss instructions on how to get the other two chromecast devices I have which are affected by the outage.  Please help.
bk88
Hopefully your fix will help my situation too: Although I didn't do a factory reset, I did "remove this device" and that seems to have gotten hung up (I no longer see the Chromecast in HOME but I do see that it is still on the network.)
mjjg1500
Hello....
All of my (Three) 3rd generation Chromast devices stopped working....I tried a factory reset....then setup....no luck ....
Error message
Unable to authentic device...
All three devices are presently in setup mode....
Please advise.
Best regards.
MG
Thanks..
Sorry
Error message again;
Unable to authenticate device.
Thanks
MG
AlexanderJCM
To say, just now, not to restore the factory default is to try to revive a dead man!
Giorgia23
azie io non so che modello ho di chromecast, si attacca al televisore per farla diventare smart tv, l'horesettato perche era collegato ad un'altra rete wi fii. il problema e' che si collega ma poi mi dice che ha il problema della rete locale dell' iohone, quando invece e' fleggato.
jamespsims1
Is this fixed yet? Mine not working at all
Not! Not fixed
CjbMarco
Oooos.  I did factory reset.  The home app says it’s connected.  However I can’t connect it to wi Fi at this time.  Keeps saying try again
Bengt311
Jag vill också veta
RikettyKate
The company sent an email to users to say that its engineers are "working to resolve this as soon as possible, and will keep you updated when there is more to share.”  This was in a news article. I have not received an email or even a notification from google. Did anyone
I don’t know for sure. But I’m using the home app and just keep trying to add device.  Everything goes good except it fails to connect to wi fi and says try again.  I guess as soon as the glitch gets fixed it will connect.  I’m hoping.
Diana101
This is a very annoying and unacceptable development for all of us; however I had a different software problem that knocked out two of my laptops, I live in a rural area with poor TV signal. So here I am with a small cell phone in my hand is my only means of communication and I cannot use my Chromecast I cannot use my television screen this is really really annoying. It's unacceptable to tell us that you will roll it out as soon as possible without giving an estimated time frame of a solution. And if you cannot solve it then give me my **bleep** money back because there's nothing wrong with the device. Elsewhere it stated that a license expired and that's why they stopped working on a particular date. So what is the reason? At least inform us of what the issue is.
  I'm also very annoyed because I called about the problem wasted countless hours trying to fix this and your staff members said nothing about this to me. And being that my laptop was down I wasn't really in the mode of searching online for information about what was going on and never dreamed that it was universal I thought it was only my chromecast. You should have had the decency to let us know, you should have the decency to tell us what the reason is now. Otherwise I think I'll be going over to  Apple. My sister uses all Apple products and she never has these issues, never!
rob6462
When does the license expire for the generation three Chromecast? If it’s in the next six months, is there going to be a fix for that before it happens?
clokclochab07
j’ai déjà réinitialiser en mode usine que dois je faire ?
Catcast
I have already reset my device as I didn’t know what shall I do now?
Many thanks,
Tamlyn
Waiting for new instruction because i factory reset the device
Knoxman74
Resetting the device was the first thing many people did. That was even originally adviced by you guys. My next streaming device will probably come from a fruit company
AinsRay
If it can't be fixed, please just say something and I can try to buy a new device to stream. In limbo all week and I've had enough. I've got football to watch on the weekend! C'mon already! #ialsodidthefactoryreset
Lauwinter59
Aguardo con desesperación la solución! Mi Chromecast funcionaba perfecto!!!!!
Carlotiky
Llevo dos días q no hay manera, he hecho todo lo q he visto en internet y hoy me encuentro un sitio donde habla de q hay un problema a nivel general con estos dispositivos y q no se nos ocurra reiniciarlo de fábrica. TARDEEEEEE!!!!!! Es uno de los pasos q he hecho. Y ahora qué? Cuento tiempo vamos a estar así?
Gloriamicaelo
Chromecast is not working. What is happening?
