GoogleNestTeam
Community Manager (Admin)
Update 3/20/25
Update 3/17/25:
Update 3/14/25:
Update 3/13/25:
Update 3/11/25:
Hi all,
Thank you.
Thank you for your patience.
GoogleNestTeam
16,131 REPLIES 16,131
kingf
still no fix!!!
IsabelRod
Mis Chromecast siguen sin funcionar.. no entiendo para que dicen que ya esta solucionado el problema si es no es cierto.. y de paso te dicen que sino hiciste reinicio de fábrica el más complejo volver a programarlo.. pero estoy segura que un gran porcentaje de personas que lo usan hicieron eso.
Obviamente, millones de usuarios reiniciamos el Chromecast intentando hacerlo funcionar de nuevo. Es lo lógico. Veamos si nos dan solución pronto, que ya van 5 días.
César_Rojo
Habéis intentado que compremos el Chromecast nuevo que vale una pasta… y habéis perdido. Arregladlo y no intentéis jodernos más… o perderéis millones de clientes.
Stelica
Am aceas proble  cu cromcastul. Spune.  Dispozitivul Chromecast
nu a putut fi autentificat, va rugam sa ne ajutați cu rezolvarea problemei
Toată lumea are aceeași problemă. Milioane de clienți furiosi așteaptă o soluție de la Google.
Anamtalha
Plz solved my authentic issues
Jae93
How will we know when it is fixed
Jstapp24
I allready factory reset now it stays on a screen that says download the home app please tell me how I can get it back up wont connect please
Mirjam
I have reset my device 😢
Kat-Anne
Hi do you have a rough expectation of when it'll be fix? Thank you for your hard work in getting it sorted. I did a factory reset prior to knowing that I didn't have too
CannyStyle
Chromcast 2nd gen. already facotry reset before reading the warning. As other users suggested I set back phone clock earlier than 8-Mar. Was then able to connect but when trying to Cast still not recognizing wifi network (missing/not finding device to cast...of course the same of phone). So not working yet. Looking for updates
Badzazael
What's the fix
Stelica
Din păcate la resetat😪, așteptăm rezolvarea problemei și îndrumarea pașilor car trebuie urmați pentru a-l face functionabil pentru cei care am  resetat deja Cromecast. Mulțumim și așteptăm cu nerăbdare rezolvarea
johnnyzero2
I can confirm that the workarounds posted on Reddit and elsewhere will indeed restore Gen2 casting from Android devices and Chrome browser (sorry, iPhone users). I had mine back up 'n running by Monday morning. Not perfect, but for those who are impatient (and reasonably tech-savvy), it's a viable option until Google issues a proper security certificate fix.
https://www.reddit.com/r/Chromecast/comments/1j7lhrs/comment/mgy1a88/
https://mensfeld.pl/2025/03/bringing-your-chromecast-back/#how-to-fix-it
mpez
Would this work if I've already done a factory reset? Thank you!
Yes. That's addressed in the instructions.
tommyemoss1980
Getting ridiculous.. pay good money and expect it to work.
You paid at most 50$ for it … I had mine for close to 10 years now ( or close to that ) .  That’s 5$ a year , I can wait a fews days or weeks without it .
lmb13
I had already reset my device.   How do I connect it now ?
lmb13
I had already reset my device so how do I get it working now ?
NeRoDusty
You owe me compensation for your horrible service
Nabor
Qué vergüenza de compañía Google!!!!. Se cargan los chromecast más antiguos así de repente. En plena víspera del partido de chamipons. Es increíble:!!!. Y se quedan tan tranquilos como si no hubiese pasado nada. Millones de usuarios sin poder acceder al servicio de los equipos que pagamos en su día.
See this post.
It's not the final solution, but it might help you
Para IOs sabéis si hay alguna solución?😔
DanielleMez
This is a 2nd post, bc I would like to make you all aware at Google, that due to the very late notification (which I found via reddit,from something you all posted) , I only found out to not factory reset way too late. If I had been notified several hours prior this would have saved me me hours of my time & factory resetting both of my Google Chromecasts. I work in tech support & I find it completely unacceptable that this IMPORTANT detail wasn't made available sooner & that this is step wasn't removed from your Google ts steps. I now have 2 inoperable Chromecasts & 3 days later no resolve. What's the ETR? Will we be notified or will I have to search Google again?
100% same situation
MiAnny
Quando vamos conseguir assistir novamente? Já faz dias que está assim...já que é por conta de atualização pega esse e nos dá o novo ou pagamos a diferença,mas depende do aparelho pra transmitir do celular
Vahan1998
Paulavargas25
Arreglalo que juega bocaaaaaaa
BartGral
When can I expect that issue with not connecting to chromecast 2 gen will be fixed?
Byteguy
Gold Product Expert
Gold Product Expert
Google is aware of this and working on a fix.  We do NOT know when that will be but Google says this is high-priority.
Jufmiranda
Hi, unfortunately. When my google chromecast refused to work, I’ve resettled it…AFTER checking the internet if something was wrong worldwide. At that time, I couldn’t find feedback about it, so I thought I’d was an issue with my chromecast. The next morning there was information about the worldwide issue. Way too late! I don’t have money to buy a new one. If I was rich, I had a smart-Tv… I’m sad….
Hola, buenas tardes. Puedes volver a configurarlo si colocar fecha y hora previa al 9/3 en tu celular, luego lo reseteas otra vez y vuelves a configurar.  A mi me funcionó y por lo menos tengo foros y un reloj gigante hasta que nos den una solución definitiva. Después vuelve a colocar fecha y hora automáticamente en tu celular.  Espero ayudar, así como me ayudaron a mi. Saludos
Byteguy
Gold Product Expert
Gold Product Expert
Google says that they will explain what you need to do when they have a fix.   At this point, they are NOT saying you have to replace it.   Just wait for their fix.
I did the same, but just read a post about changing the date on your phone to before 9/3 (i think the reply above says this in Spanish) and tried the configuration again and it worked. Now I have the device set again: but I still can’t cast anything but at least it is now connected to my network
AleSpinelli
Eu sei que há uma pane no sistema do ChromeCast, mas eu espero que isso se resolva. Será má fé da parte do Google se este problema não se resolver. Isso é obsolescência forçada.
I know there is a glitch in the ChromeCast system, but I hope this gets resolved. It will be bad faith on Google's part if this problem is not resolved. This is forced obsolescence.
Hopper1485
Tantos expertos en el tema, que trabajan en Google y no pueden arreglar el problema que tiene el Chromecast, es increíble usemos otras marcas mejor y hacer un boicot contra la marca, a ver Trump haz algo
Mangan
Not very trustful product...have to stick with my Applebox then...same age 10 years as my chromecast and still working...🙄
