Update 3/20/25
Update 3/17/25:
Update 3/14/25:
Update 3/13/25:
Update 3/11/25:
Hi all,
Thank you.
Thank you for your patience.
03-20-2025 10:49 AM
03-12-2025 08:27 PM
But your first communication said to factory reset the device. Now you're saying to not factory reset it? Thanks 👍 When is the fix coming!?
03-12-2025 08:34 PM
It was arround 5 days now. Expecting faster resolution... search your issue in google and fix it.
03-12-2025 08:34 PM
Hola, tarde ya lo reinicie lo cual sigue sin funcionar. 🤦🏻♀️
03-12-2025 08:50 PM
Puedes volver a configurar cambiando la fecha del celular con el cual configuras y transmites contenidos al chromecast: cambia la fecha en tu celular al 7 de marzo, luego vuelves a realizar los pasos que normalmente harías para configurarlo, luego déjalo así nomas, hasta que los inoperantes responsables de todo este problema nos envíen nuevas instrucciones, por lo pronto habrás logrado configurar tu chromcast y verás los lindos paisajes de G. home.
03-12-2025 08:36 PM
Quiero soluciones
03-12-2025 08:36 PM
How long it might take to address this issue
03-12-2025 08:41 PM
03-12-2025 08:41 PM
Any idea when the issue will be resolved?
03-12-2025 08:47 PM
cuanto más tengo que esperar
03-12-2025 08:47 PM
Hasta cuando???????
03-12-2025 08:48 PM
Please solve this because there are lots of people who did the factory reset without knowing it was a best thing to do given a bad communication.
03-12-2025 08:48 PM
First thing I did was factory reset it, based on your darn recommendations
03-12-2025 08:49 PM
Everyone did... 😂😂😂
03-12-2025 08:57 PM - edited 03-12-2025 08:58 PM
This is an issue not only for 2nd gen Chromecast. I'm getting the device cannot be verified error on my 3rd gen Chromecast as well when I try to cast from YouTube my phone. Can we please make sure the resolution will work for 3rd gen as well please?
03-12-2025 08:58 PM
Yo lo reinicie de fabrica que puedo hacer
03-12-2025 09:07 PM
Please email me or put up a post here to keep me updated.
How do I know if my device is Gen 2 ? Nothing written on it or the box
03-12-2025 09:13 PM - edited 03-12-2025 09:20 PM
If it stopped working on March 9th, then it's a Gen2. 😉
03-12-2025 09:09 PM
I bought Chromecast due to Googles product. But issue solving is so slow ...its really frustrating. I need to think twice before buying products from Google now onwards
03-12-2025 09:11 PM
please let me know when you fix the problem I did factory rest
03-12-2025 09:13 PM
Tienen idea de cuando arreglarán el issue que nos ha desconectado a lo bárbaro???
03-12-2025 09:15 PM
Aun no tienen solución?
03-12-2025 09:18 PM
Quick way around… follow these steps.
-change the date in your phone to March 7th, 2025.
- go to the app and connect your chromecast .
- then go back and change the date to the correct time.
- all done… enjoy
03-12-2025 10:42 PM
Asuman thank you.
Everybody this works.
Google shame on you.
03-12-2025 09:19 PM
I did a factory reset what do I do now? I just saw this msg.😩
03-12-2025 09:23 PM
Even if you did a factory reset it will work.
follow the steps above^^^^^^^
03-12-2025 09:48 PM
it doesn't
03-12-2025 09:14 PM
Can you please just do an update to the home app setting an internal clock update which prioritizes in the coding over the device clock so that the "daylight savings" issue is fixed? 😕 I don't understand why it's gone for days not getting fixed from one the largest companies in the world
03-12-2025 09:25 PM - edited 03-12-2025 09:27 PM
It has nothing to do with "daylight savings". It's a problem with an expired security certificate.
https://www.reddit.com/r/Chromecast/comments/1j8wtxa/heres_why_a_fix_is_taking_so_long/
03-12-2025 09:20 PM
Hi. When is the issue going to be resolved. I have factory reset it already
03-12-2025 09:22 PM
リセットしてしまいました。
再セットアップはできないのでしょうか?
03-12-2025 09:23 PM
Uh, factory reset is a natural troubleshooting step before I go to the forums looking for answers...
Hopefully the fix will work anyways when its pushed out.
03-12-2025 09:25 PM
How many hours/days we have to wait. Some people will go buy newer ones, Lots of $$ google would make during the wait.
03-12-2025 09:31 PM
Pity this didn't come out sooner before most of us had reset our devices!
03-12-2025 09:37 PM
A 40 to 60% discount on the Google Stream would definitely get me moving forward. thanks for the break from streaming. It's a great time to have a sale. asking for a million friends... 🥰
03-12-2025 09:38 PM
Yes- I have factory reset device
03-12-2025 09:38 PM
Is there an ETA on an update on this so called fix? The amount of people that use a Google stand alone product to be able to achieve their device usage and needs is being affected world wide. This is beyond a joke that a corporation of your size forgot to update a licence certificate patch and that this has not been resolved begs me to ask are you out of your depth on this one. That is alarming and very concerning.
Provide an update ASAP as this is concerning many users at the moment and your effecting our enjoyment time the longer the service/s are down.
Take this as my formal complaint today being Thursday the 13th of March 2025 at 15:37est ( Melbourne, Australia)
I will be making contact with the ACCC here in Australia regarding the issue at hand.
03-12-2025 09:41 PM - edited 03-12-2025 09:54 PM
It's a 10-year-old sub-$30 TV dongle.
But, you do you.
03-12-2025 09:39 PM
Not great, I was planning on upgrading some of my devices. But now I am considering other products due to how this is being handled.
03-12-2025 09:39 PM
How much longer to wait
03-12-2025 09:01 PM
I resetted and it still tells me it can't connect. So frustrating 😫
