Update 3/20/25
Update 3/17/25:
Update 3/14/25:
Update 3/13/25:
Update 3/11/25:
Hi all,
Thank you.
Thank you for your patience.
03-20-2025 10:49 AM
03-09-2025 05:31 PM
Glad to know it's not just me. I spent a lot of time trying to figure it out.
03-09-2025 05:32 PM
Same here, tried factory reset and reinstall but google home says "impossible to authentify your chromecast. To solve go to support.google.com/chromecast". Ihave chomecast gen 2 and chromecast audio. I can see the pending wifi ssid of both Chromecast, i believe in a google bug.
03-09-2025 05:33 PM
Same, my older Chromecast won't authenticate.
03-09-2025 05:36 PM
Just started here in NZ too
03-09-2025 05:38 PM
Chromecast audio says cannot authenticate when trying to add it to Google home.
03-09-2025 05:39 PM
gente o que houve ? sou do Brasil e estou com problemas também pra conectar meu dispositivo chromecast. diz na mensagem que nao consegue se comunicar com meu telefone no caso IOS testei em um dispositivo android e tbm nao funcionou. ALGUEM ME AJUDA
03-09-2025 05:40 PM
Even after I factory reset it is still saying something about the firmware and it won't authenticate it
03-09-2025 05:41 PM
Chromecast 2 com o mesmo problema. Parou de nada. Nenhum procedimento funcionou. Brasil
03-09-2025 05:42 PM
Same problem here in Argentina
03-09-2025 05:42 PM
queremos sangre google! entrega al responsable de este caos! que rueden cabezas!! MUAAAJAJAJAJAJ
03-09-2025 05:43 PM
I want to know what Google is doing about it? If I have to buy a new device, you can be sure it WON'T be a Google one
03-09-2025 05:43 PM
I'm also having the same issue, glad it isn't just me
03-09-2025 05:44 PM
Same; was fine recently; even after power cycle/factory reset! Now I have issues with 3 Chromecast devices.
03-09-2025 05:44 PM
Global issue with old gen Chromecast
Waiting for Google to fix or will they stop supporting old working Chromecast device?
03-09-2025 05:44 PM
I have the same problem in Ireland.. I've tried every troubleshooting tip available including factory reset and using different phones, nothing works.
03-09-2025 05:46 PM - edited 03-09-2025 05:52 PM
É complicado como um erro aparentemente com o Google Home impacta a todos ao redor do mundo. Quase dá pra acreditar que é pra forçar a barra pra troca para aparelhos mais modernos, pra tirar os antigos de circulação.
tenho um Chromecast gen 2 e funcionava muito bem até alguns momentos atrás, quando parou de transmitir e apresentou esse erro.
Resolvi redefinir pra tentar resolver, agora o mesmo não autentica mais. Parabéns Google, por mais uma ação decepcionante.
It's complicated how an error with Google Home apparently affects everyone. It's almost believable that it's to force the switch to more modern devices, to take the old ones out of circulation.
I have a Chromecast gen 2 and it worked very well until a few moments ago, when it stopped transmitting and presented this error.
I decided to reset it to try to solve it, but now it's not authenticating anymore. Congratulations Google, for another disappointing action.
03-09-2025 05:46 PM
The same thing happened to me with my two Chromecast 2
03-09-2025 05:48 PM - edited 03-09-2025 05:48 PM
Google, did you just brick my dozen Chromecast devices or is this just temporary ⁇
03-09-2025 05:50 PM
Same! I'm really frustrated, I feel like I've been trying to fix this all day! I'm glad to find that I'm not the only person having issues- at least that's a relief. Honestly, if this can't be resolved soon I'll likely replace with a competitor..
03-09-2025 05:50 PM
mismo problema desde Argentina
03-09-2025 05:51 PM
Same here in Mexico
03-09-2025 05:52 PM
Looks like I'm going to go buy the newest Amazon Firestick!!! This is bull! There's no way to get any help from Google! If there was and outage or scheduled maintenance or some other reason, they should at least put the reason on the Google Home ap!
03-09-2025 05:53 PM
Mi Chromecast presenta error no auténtica
03-09-2025 05:55 PM
nadie responde de Google, eso genera mala publicidad!
03-09-2025 05:56 PM
I'm having the same problem in Argentina, does anyone could fix it?
03-09-2025 05:59 PM
Same, following
03-09-2025 06:00 PM
Way to make a buck #Google! £100 for the new Google Streamer to replace failing Chromecast that worked perfectly fine until now. Absolutely furious 😡
03-09-2025 06:00 PM
Mismo problema. Tengo 3 Chromecast generacion 1 con el mismo error. Ya probé restablecer de fábrica los 3 y siguen igual. Media pila Google!
03-09-2025 06:16 PM - edited 03-09-2025 06:22 PM
Same here, I got a v2 (I think) and the sale problem today. I tried reset but doesn't work.
03-09-2025 06:16 PM
What the heck does can't authenticate even mean? It's a legit Google Chromecast product that I have used for past few years without any issue. If what others are saying is true and this is the result of a firmware upgrade, then Google should be compensating customers for this inconvenience.
03-09-2025 06:26 PM
Hola igual, ayer funcionó mi Chromecast 2da generación, hoy no funciona, reinicie de fabrica, instale nuevamente app Home . No funciona
03-09-2025 06:26 PM
Same issues, any idea what to do?
03-09-2025 06:26 PM
Smae thing, till yesterday it was working fine, today wont even connect
03-09-2025 06:26 PM
Same issue here. Frustrating!
03-09-2025 06:28 PM
same for me
03-09-2025 06:29 PM
Same here. When is the fix coming!!!
03-09-2025 06:32 PM
Disappointed and unfair; Google has no right to damage products we have purchased.
03-09-2025 06:38 PM
Not working in Australia either
03-09-2025 06:39 PM
Same thing in Uruguay. Today my 2 chromecasts do not connect.
03-09-2025 06:41 PM
I'm having the same issue. Even after factory reset.
