GoogleNestTeam
Community Manager (Admin)
Update 3/20/25
Update 3/17/25:
Update 3/14/25:
Update 3/13/25:
Update 3/11/25:
Hi all,
Thank you.
Thank you for your patience.
GoogleNestTeam
16,122 REPLIES 16,122
Yo tengo 2 y ninguno funciona no agarra el wifi
Liviniitup2
I already factory reset the device before I knew it was an issue
Ian23
Osea que esto le pasó a todos?
Sinnombre
Nos van a indemnizar?
tommyemoss1980
Think company morons.. can you imagine the amount of people rest the chromecast. Get a brain google..3 day now, pull finger out
RORHT
Reinicie el dispositivo Chromecast a "restablecimiento de datos de fábrica".
Eliminar el dispositivo Chromecast de la aplicación Home
Desinstalar la aplicación Home
Instala la aplicación Home
Poner la fecha de manera manual en el teléfono (fecha anterior al 8 de marzo ) y una vez hecho todo lo anterior proceder a configurar en la aplicación Home el dispositivo y permitirá su configuración, después de configurado poner la fecha y hora automática en el teléfono y listo.
Ian23
También lo hice pero no sé puede transmitir
Bludel1283
I can't conect
Emusk
4 in a row wins
Alex666
What happens if I factory reset the device?
Emusk
You could open a portal to hell!!!
Sonchai
 Hi GogleNestTeam,
my IT guy just factory reset of Gen 2, please give me a solution to get it back.
Thanks.
Marmic71
Mi spiace ho fatto tanti tentativi, ho ripristinato il dispositivo. Spero di poterlo recuperare. Grazie
Kasiayildiz2558
Four days its not working. I tried to reset. And now I cant even re-setup. Fix this asap!
Jackie_chen
Already reset to factory.
need  you to fix this problem ASAP.
hacknerdianne
I hope there’s some type of paylback for all of us.
Febi
Hi.. I factory reset my chromecast since that is the 1st thing I have done whenever something went wrong. So, please let me know if the fix you will implement would be applicable to such devices too. Also, when can we expect the fix to be implemented. Thanks.
Bartzok
Too late to say don't do a factory reset when it's one of the suggestions included in reconnection instructions after trying other steps first! Aaaaaarrrgggghhhh.
ashutosh_raghu
You have not specified the issue in detail but I am experiencing an issue with both 1st and 2nd generation Chromecast devices.
The issue is simple, I am able to cast (YouTube and other apps) to these devices but they are not showing the personalized pictures in ambient mode. The 2nd generation Chromecast was set to show pictures from my Google Photos but it is showing some random pictures from Internet. The 1st generation Chromecast was set to show paintings and artworks which is working fine but I when I try to change anything with my Google Home app, both devices are being shown as "Offline".
Epona1
I pay for my streaming services and this is not ok. Why no solution yet? Off course I reset my chromecast! It said to do so on your advice-paige last sunday when the chromecast died!
Åsaåsa
Most of is already tried to reset ….
kaurfeelgreat13
Am already done device factory reset but after that don't connect
Caro1
Hi, is there an update on the fix? I need instructions on what to do after a factory reset sent to me please.
Tt6
Any update?
Glam_Soul
I want my Chromecast back! ASAP
Google, you have the worst customer service. You should fire your engineers who couldn't solve the problem.
I went to play Spotify on my stereo AND THAT DOESNT WORK EITHER  Argggh
RF3
I am waiting for a Xiaomi stick which will make my old TV a bit „smarter” so goodbye Chromecast 👏
Lucifer_Libeau
4 days and still no solution?
Good thing this is not a Life or Death situation......
Pagiouras
I am very disappointed on how Google handled the whole issue and for their significant delay. 4 days after and only apologizing messages.
Jeronimo1
Llevo cuatro días así que no funciona el dispositivo los restablecí a ajustes de fábrica puedo tener ahora algún problema?
PavanKumarN
We got wifi changed and after doing factory reset we found this information not to reset. Now we are not able to connect Chromecast agai
Prassi
Unfortunately due to issue at Chromecast I did reset.. now I am unable to connect. Kindly help us fixing the issue asap . It is impacting my kids.. thanks
Jayvas2
When will I have my device fixed because I need it to work I have great connection
Diego26
Nice to know that is and already known issue, but reading not to restart the system here is too late as Google recommends to do it as first thing in its troubleshooting guidelines.
KCV
Præcis
letmeknowanand
When will the update come what is the ETA - I already made a factory reset
mikekaast
To all of you, who have already reset the device to factory default. do this to get back to start: your device will be ok. Just find an old ipad, or an old android phone, set the date on your device to Mar 8, and setup your chromecast as normal from the google home app, and your all set. BUT you still cant cast anything, you will get the message:  Unauthorized device : until google fix this problem.
Oscar8
I've found a workaround for this issue, check it out
https://vt.tiktok.com/ZSMGy5A3K/
