Update 3/20/25
Update 3/17/25:
Update 3/14/25:
Update 3/13/25:
Update 3/11/25:
Hi all,
Thank you.
Thank you for your patience.
03-20-2025 10:49 AM
03-13-2025 06:58 AM
Hello.
This is seriously F***** up! For some of us this is our only way to watch TV and if you are early retired with a body in pain, this is also the only thing to pass time 😡😭
Writing that we shouldn't factory reset is almost hilarious cause honestly probably most of your users did that within the first hour on the day this breakdown happened, either on their own, searching Google for or calling any kind of support.
So I serious hope you have that in mind, logically thinking maybe 5% didn't do it!
03-13-2025 07:00 AM
Quando teremos a solução para o problema? gostaria de poder usar meu chromecast ao invés de torná-lo um peso de papel.
03-13-2025 07:00 AM
What happens if you have already reset your device. as its is listed in the troubleshooting guide.
before finding out that there was a greater problem with the Chromecast devices.
I hope they find a solution for the issue soon as it would be a shame to lose such a device as the Chromecast.
I often travel with this device when we are on long drives or on the ocean.
in helps to be able to settle my neurodivergent children. By allowing them access to their favourite tv shows no matter where I am in the world. Or what time of day or night it is.
This device has been a amazing tool for me and my children.
03-13-2025 07:09 AM
First let's hope they will solve the certificate problem. Then there will be a way to bring our Chromecasts back on.
03-13-2025 07:01 AM
Any news?
03-13-2025 07:02 AM
Hi, I'm Marcelo Costa, from Argentina.
My Chromecast suddenly stopped working about two weeks ago. Not knowing regarding your recommendation to "not reset to factory settings", we pressed the little button and restarted the device to factory settings.
Now my Chromecast won't sync with the Google Home app on my phone.
The app recognizes the Chromecast, indicating its number "chromecast8204," and then the code E5X8 automatically appears on my TV screen, requiring me to validate this code in the app on my phone. However, the app never allows me to validate this code. Additionally, the app displays a message indicating there is a problem and recommending contacting Google support.
How can I solve the problem?
03-13-2025 07:14 AM
Es un problema de google, lo estan tratando de solucionar
03-13-2025 07:21 AM
Nosotros nos pasó lo mismo. Hace cinco días.
03-13-2025 07:49 AM
Podés volver a sincronizarlo si cambias la fecha de tu celular manualmente a antes del 9 de marzo (día en que comenzaron los problemas).
De todos modos no está funcionando el envío de multimedia, pero supuestamente están trabajando para solucionarlo. Espero mi respuesta sea de ayuda!
03-13-2025 07:03 AM
WHEN????????
03-13-2025 07:04 AM
I reset my device to factory. What should I do now?
03-13-2025 07:23 AM
I think it's just a matter of waiting, part 2 of the solution that's pending.
03-13-2025 07:05 AM
The days are ticking by and still no fix. Millions of devices dead in the water, millions of PAYING customers without a functioning product.
Incompetence reigns...
03-13-2025 07:06 AM
When trying to fix it in the first place, part of Google instruction (and final step) was to attempt Factory Reset so we did to no avail. We will not retry.
03-13-2025 07:08 AM
No ví la notificación de no reiniciar el aparto, y no puedo configurarlo , ayuda
03-13-2025 07:30 AM
Están trabajando en esta parte de la solución porque muchos otros hicieron lo mismo.
03-13-2025 07:11 AM
Eu já restaurei a configuração. Peço que me ajudem por favor.
03-13-2025 07:28 AM
Eles estão trabalhando nessa parte da solução, assim como muitos outros fizeram o mesmo.
03-13-2025 07:14 AM
not working
03-13-2025 07:15 AM
Fix it asap!
03-13-2025 07:17 AM
How can I be informed when the issue is fixed ? Do I have to check this page out regularly ?
03-13-2025 07:20 AM
Quiero mi Chromecast funcionando otra vez!!! Cuándo lanzan la actualización?? a mi dispositivo no llegó
03-13-2025 07:21 AM - edited 03-13-2025 07:23 AM
I'm a fan of Google. I have YTM and Youtube Premium, Google One, Gemini subscription (the last is still a tryout) Just a thought. I have 4 Chromecasts Audio and three Chromcast for TV. All these in two locations. The Audio Chromecasts I bought on classiffied for about 100 USD each. This way I can use my old Stereo HI FI equipments, and trust me they are WAY above all those active speakers that you can buy now. I have grouped my Stereo systems to streame the same Youtube Music I have a Premium Subscription. Just last week I bought two other Audio Chromecasts also on classiffied. Approx. 70 USD each. Chromecast Audio is a High Resolution piece of equipment. It has audio jack and optical output. Youtube Music sound quality is similar to Tidal and probably better, anyway it sounded better to me and other friend (that work with sound in cinema) when made a hearing test YTM vs Tidal High Resolution. For now, all this is gone. It is not bad enough that Google do not make Audio Chromecast anymore, now we cannot use them anyway. I only hope Google cares about their Customers. We that use Chromecasts are not corporate, but Google is big because of us, the small customers. Please do not let us down!
03-13-2025 07:24 AM
Is there any update yet?
03-13-2025 07:25 AM
Any News??
03-13-2025 07:25 AM
It’s a bit late …. I have spent hours trying to reset device without success. Now you tell me I shouldn’t have attempted to reset. When will it work again?
03-13-2025 07:29 AM
I have factory reset the device. Through which channel will you announce when the problem have been solved?
03-13-2025 07:31 AM
Me resolvieron el problema?
03-13-2025 07:30 AM
Please take youre time and send a mail and inform google customers on this silly chromecast malfunction ...
03-13-2025 07:39 AM
What date are you hoping to have it fixed for the users that did the suggested factory reset?
03-13-2025 07:41 AM
How long do we wait
03-13-2025 07:40 AM
Porque medio nos van a informar la solución al problema? Va a haber algún tipo de resarcimiento por los días que nompodemos utilizar los dispositivos ?
03-13-2025 07:42 AM
First you broke my Pixel 4A and now my Chromecast Audio. Should I even consider buying a Google product in future? I had planned to upgrade my Pixel 7 to Pixel 9 and with this kind of issues I better buy Non-Pixel Android devices!
03-13-2025 07:42 AM
Cuando se podrá solucionar la conexión con mi Chrome cast?
03-13-2025 07:44 AM
5 jours toujours rien très déçue d'une grande entreprise comme Google ma confiance dans votre entreprise n'est plus là
03-13-2025 07:48 AM
What if I already reset my chromecast because that’s how I normally troubleshoot ??
03-13-2025 07:49 AM
This controls my heat!!! It’s 62* in my house
03-13-2025 07:48 AM
繋がらないからリセットした、このあとどうすればいい、早く解決してください。
03-13-2025 07:51 AM
llegaron tarde con el aviso. Ya lo resetie . Como se hace para recuperarlo.
Necesitamos una respuesta inmediata
03-13-2025 07:52 AM
Buonasera..quanto tempo ci vuole x risolvere il problema?non posso vedere nulla così...attendo risposta...mi dice sempre che sono offline...grazie
