Update 3/20/25
Update 3/17/25:
Update 3/14/25:
Update 3/13/25:
Update 3/11/25:
Hi all,
Thank you.
Thank you for your patience.
03-20-2025 10:49 AM
03-13-2025 07:53 AM
I moved to new flat and it’s impossible to install my camera
03-13-2025 07:57 AM
Do I need to reset everything and start all over ?
03-13-2025 08:52 AM
No don't reset... Just wait
03-13-2025 07:55 AM
“We will keep you updated” - silence since Tuesday 🙄 Might as well cancel my Netflix, Disney, Paramount etc as there doesn’t seem any urgency to sort this out. Probably hoping to get lots of sales of new devices if they drag their feet. Not on my watch!
03-13-2025 08:11 AM
Aguardo ...mas já sem paciência...
03-13-2025 08:13 AM
I have already reset, the issue has been present for days.
03-13-2025 08:14 AM
I just turned the chromecast into a factory setting and it still doesn't work how long will it take?
03-13-2025 08:16 AM
I have factory reset the device as i thought it was my internet connection issue. Can you provide me the instruction to set up in my Google Home app again? Cos it says that “couldnt connect to the device”
03-13-2025 08:16 AM
En nu ? Afwachten ? Ik heb beide chromecastst dus wel geresett op aanraden vd gebruiksaanwijzing.
03-13-2025 08:17 AM
This is a very big disappointment for a long time google user such as myself, please fix this issue as soon as possible.
03-13-2025 08:17 AM
What if it already got factory reset before we actually knew what the problem was?
03-13-2025 12:58 PM
Change date on your phone to a date before 9th of march. It will let the device reconnect to the network. When connected to the internet it will not work due to understanding that the date is past the certificate. But is now connected to the internet = will get the push update from Google. (I don’t understand why Google isn’t writing this but.. yeah)
03-13-2025 08:21 AM
Cuando darán una solución a los usuarios que resetearon de fabrica??
03-13-2025 08:21 AM
When can we assume a fix on this? It is several days ago
03-13-2025 08:25 AM
Se restableció el equipo a la configuración de fábrica atendiendo a sus propias indicaciones que originalmente aparecían en su procedimiento para la solución de problemas.
03-13-2025 08:26 AM
So how do I make it work again?
03-13-2025 08:28 AM
Is it possible to get a notification if there are news regarding this problem?
03-13-2025 08:29 AM
you can subscribe to this article, but be aware you will flood your mailbox. I have disabled it
03-13-2025 08:32 AM
Estimated time?
03-13-2025 08:34 AM
Still waiting on those instructions for how to fix for those of us who factory reset?
03-13-2025 08:35 AM
03-13-2025 08:36 AM
@@#₼&_-()=%?!
03-13-2025 12:58 PM
03-13-2025 08:36 AM
Fixar de problemet så är misstaget förlåtligt.
Om inte så låt oss inte belöna google genom att köpa nytt från dem igen. Då bör alla 20 miljoner + köpa från konkurrenter i fortsättningen för då kan man uppenbarligen inte lita på att google tar ansvar för produkter de säljer. Evig köp-bojkott är det som svider mest för oseriösa företag
03-13-2025 08:39 AM
Desde segunda-feira que não consigo ligar o Chromecast pois ele até aparece mas depois não dá para ligar...
Estou a ficar desesperado com tal situação!
Preciso de ajuda o mais rápido possível!
03-13-2025 08:41 AM
Any update on this?
03-13-2025 08:43 AM
Why it was not informed prior via google home notification when device stopped working and we are troubleshooting we are getting to know that there is device issue, very disappointing approach!
03-13-2025 12:38 PM
Bilmədim belə olar
03-13-2025 08:44 AM
Y aló he reiniciado de fabrica lo siento.
03-13-2025 08:45 AM
Cuánto tardarå en arreglar el problema?
03-13-2025 08:44 AM
Por favor necesito solucionen el problema lo antes posible! Gracias.
03-13-2025 08:46 AM
Jag har råkat återställt min chromecast-när får jag instruktionerna så jag kan säkerhets kopiera min chromecast
03-13-2025 12:56 PM
Ändra datum på telefonen till ett datum innan 9 mars. Det låter enheten koppla till nätverket, väl kopplat till internet så förstår den att certifieringen är utgånget och problemet finns kvar, men den kommer vara kopplad till internet = när Google väl skickar ut uppdateringen med nya certifikatet så sker det på din enhet också.
03-13-2025 08:48 AM
Se ve que es un problema generalizado y no solo mío ....me d amas tranquilidad,pero mucho más coraje.......
03-13-2025 08:48 AM
So its now Thursday ? How long is this going to take. Also has anyone had any success in reaching a live person for support?
03-13-2025 08:47 AM - edited 03-13-2025 08:50 AM
I restarted my chromecast and I can no longer use it due to a Google error? mmm
This was a great idea, just for people to buy a new one, but NO. NO MORE CHROMECAST.
03-13-2025 08:50 AM
It's easy to hack have a look on Reddit
03-13-2025 08:59 AM
Too late we already set it back to factory settings
03-13-2025 12:53 PM
03-13-2025 09:00 AM
Continue without working, any prompt solution?
