GoogleNestTeam
Community Manager (Admin)
Update 3/20/25
Update 3/17/25:
Update 3/14/25:
Update 3/13/25:
Update 3/11/25:
Hi all,
Thank you.
Thank you for your patience.
GoogleNestTeam
16,160 REPLIES 16,160
Aun no puedo configurar mi Chromecast segunda generación 🥲
How will I be notified? I'm out of the water now on my basement room TV.
Yippee. TheChromcast in the shed that I ignored downloaded an update this morning and is now working fine. The one in the bedroom that I tried to "fix" is still broken 😞 and wont connect to WIFI....
I spent a few hours trying to connect my iPhone to the Chromecast again after factory resetting it. And it always show the warning message “This Chromecast was manufactured for a different country, and may not be compatible with your Wi-Fi network”, and then the Chromecast will get stuck connecting to my home wifi. Changing my iPhone’s date solved this problem and now my Chromecast is connected to Internet.
Now I need to wait for Google to solve the casting from iPhone problem.
Anonymous
Not applicable
Não recebi nenhum e-mail com orientações, eu resetei meu aparelho e aguardo instruções.
13/03/
So I did reset mine , how long until I can use it again ? I think google should be offering a discount to purchase a newer model , for the very inconveniencing issue for over a week now .
Users around the world will try different methods including restoring factory settings. Your company must fix this problem.
Reslove this issue ASAP.
I have already reset my chromecast. So please share this instructions mannual ASAP.
One Chromecast Audio I have is back up and running, the second one is still down. At least I can confirm the fix is rolling out, definitely a staggered release, and they're not doing it by Google account.
Thank you for your explanatory note related to the "Chrome cast disaster." What happened, its consequences and Google's silence in this regard is improper of a company like Google. In any case, we hope to receive news with the solution to this "disaster"- #
Please fix this ASAP, I literally tried everything as I thought the problem was from my router or my phone or chromecast
Aqui já voltou a funcionar. Valeu pelo susto. Pensei que ia ter que expor o Gadget no meu museu particular junto com drives de disquete 3 1/2, cd-rom, modem 33.6 k etc. O novo certifiacado da Google para o Chromecast parece que será válido até 2045
Que sorte teve então. Pq aqui a mesma porcaria. Fora que a primeira coisa que fiz foi resetar aos padrões de fábrica e aí então lascou. E a Google não colabora com essa solução o mais rápido possível. Muito frustrante mesmo de mesmo.
How long will it take as I accidentally factory reset and is my only form of watching TV. Please help as soon as possible.
Still not working. Firmware v275994.
I factory reset mine, please notify me with instructions
I Factory reset it. Is this resolved?
Control + Z......should all be fine.🙈....... Not acceptable for a core product to be bricked!
Any advance on when this issue will be fixed?
What is the fix for resets?
Followed instructions online to reset and not to hear late that we are to avoid resetting chromecast. Hurry dealing with a very upset wife!
May we pull the update vs waiting for you to push it
I can not set up my device
Sres Google. Chromecast
Por favor enviarme solución para que mis 3 Chromecast funcionen nuevamente a mi correo electronico #.
Soy DISCAPACITADA y de la TERCERA EDAD y gracias a uds la estoy pasando muy mal.
Quedo agradecida
Ana María Mutti
Please fix it SOON!! THANK YOU!!
Is this happen to all chrome cast??
Any updates?
So incredibly frustrating
It's really long to fix !!!
How do you connect the device to the internet?    I left it plugged in but the device shows as offline on the Google Home app.
Infelizmente como milhares de cliente após simplesmente o chromecast parar de funcionar, resetei para as configurações de fábrica sim. Vocês não se comunicavam, 3 então não havia como saber o que estava acontecendo. A primeira coisa que se pensa, resta as configurações e volta pro padrão de fábrica. Espero que resolvam o quanto antes esse absurdo da falta de consideração com os clientes. Pq se não voltar a funcionar os chromecasts do mundo inteiro, pode acreditar que vocês terão uma chuva de críticas nada boas fora os processos pq o muita gente assim como eu gastou dinheiro e não foi pouco pelo Chrome. Pq não é barato. Parem de desculpas e resolvam.
Hurry, please
Lo reinicie, esas fueron sus propias instrucciones, dos días después me dicen que no lo reinicie! Demasiado tarde! Demasiado molesto, demasiado nefasto.
hay alguna otra marca para comprar? El fire stick también está fallando! Mejor un Google TV?
Jjjjjj72
Chromecast?
You show my  password ass nic ,thans for that  allso. Chrocast has been briged a week, soo how are you hanning?
I hope it is soon!
Please be kind enough to keep me posted of the remedial action by email to # soo. Best regards to all!!!🙏🙏
Por favor reestabeleçam o chromecast urgente. Somos muitos que detem o aparelho. Responsabilidade de uma boa empresa em zelar pelos seu público de direito
