GoogleNestTeam
Community Manager (Admin)
Update 3/20/25
Update 3/17/25:
Update 3/14/25:
Update 3/13/25:
Update 3/11/25:
Hi all,
Thank you.
Thank you for your patience.
GoogleNestTeam
16,157 REPLIES 16,157
Ya funciona!!!! Gracias
Does this mean if you did a factory reset it may work or it definitely will not work?...... The "may" in the post FROM Google implies it might work?
sg-01
For a device which was factory reset, the solution is to change the phone date to before March, 8 and perform the setup.
Anonymous
Not applicable
Using your device (e.g.: Android phone or whatever you have the Home App on), change the date to March 1st. Then add the new device to your home per normal. It will find it as a new device and it will connect to the network and internet again. Then it will get the new firmware
Que demora isso é falta de respeito com os usuários
I'm in...finally! It could work! Now seems everything has been fixed
Anonymous
Not applicable
If someone has reset the factory settings, change the phone’s date to March 8, 2025, open the Home app, and set up the Chromecast. Once it connects to the internet, it will receive the update. After it’s finished, restore the date and test it.
Yo you got my phone
Ho eseguito il reset del dispositivo, come la maggior parte, dal momento che la vostra segnalazione non è stata tempestiva. Il mal funzionamento mi impedisce di guardare la TV e le piattaforme in abbonamento, (Netflix,).  Dovreste rimborsare il disagio e il danno. Il tempo di attesa si sta allungando troppo.
I can confirm that my Chromecast Gen2 is now fully operational.  Thanks to the Nest team.  Most people don't realize the challenge of releasing a patch that affects millions of devices without breaking something else.  The fact that it took only 5 days is truly commendable.
Preciso dessa orientação de reset do chromecast em português e de preferência logo
Antes de saber el problema lo reinicie a configuracion de fabrica, 🤦🏻
Anonymous
Not applicable
I had reset the chromecast to factory settings. Google Home could no longer find the chromecast.
I set my phone to March 8. Then added the chromecast again with Home. The chromecast automatically updated. After the update everything works properly again : )
Set the phone back to the current date.
RdeW
O meu continua sem conectar ao celular eu tinha resetad9 quando deu o poblema e agora ?
Aqui em casa ainda não solucionou o problema,infelizmente foi avisado que não podia resetar depois que haviam avisados.E agora ?
There is a fix offered by user johnnyzero2
Do this fix
https://www.googlenestcommunity.com/t5/Streaming/Regarding-an-issue-with-Chromecast-2nd-gen-and-Chro
Leave your unit power up on your local Wi-fi network. It takes time for the google server to update the device
Ok vou ficar no aguardo
How do I update chromecast? The only way I have found to do so is via Google tv, and I don't have it.
AleTau
R
Factory reset
Roll back the data in your phone to march 6th
Use Google Home to set up
The new software will download
When finished, do a new factory reset
Restore the phone date
Setup with Google Home again
No puedo instalar chromcast
Has the issue been fixed? If so,none of my devices will connect to Wi-Fi?
I reseted it many times days ago, does it affect badly in reconnection? Btw, still the same, no news.
Roma Italia
Ripristinato i dati di fabrica come consigliato con data prima del 10/3.
Configurato con l'immagine di goglee ma non si connette a goglee home
Spero al più presto che venga aggiornato per rifunzionare.
Aspetto info
Ustedes me van a mandar la solución o lo tengo que cambiar
Any update yet for those of us who reset it?!?!?
Anonymous
Not applicable
I had reset the chromecast to factory settings. Google Home could no longer find the chromecast. I set my phone to March 8. Then added the chromecast again with Home. The chromecast automatically updated. After the update everything works properly again : ) Set the phone back to the current date.
Grazie sopporto, ora il mio dispositivo Chromecast funziona.
Fantastico
When is fix coming? I performed a factory reset, prior to reading this. Need help to get it going again please.
Anonymous
Not applicable
Hice lo mismo y funcionó perfecto
Hasta cuando hay que esperar por favor
Good evening, I am not using my device, and I reset it, which is the obvious thing I could do, now I see that it shouldn't have happened, any help with this?
my device is now as Choromecast0285, still waiting for a solution.
Most people did factory reset and are not happy it's not working for a week and no resolution timescale.
Boa noite e o pior é que reiniciei mas de uma vez tomara que consiga a voltar a funcionar.
Anonymous
Not applicable
Good afternoon! Do you already have a position on this issue?
Anonymous
Not applicable
Ya se encuentra la solución para quien reinicio de fabrica al chromscast? Hace 6 días q no puedo usarlo ! Gracias
Is there any forecast for all devices to be working correctly instead of having to reset the date on my device?
Los que hemos reseteado sin saber que nuestro dispositivo quedaría para pisapapeles recibiremos una solución?
Ça aurait été sympa de prévenir avant en ce qui concerne la reinitialisation car pour l'instant je me retrouve sans rien
