GoogleNestTeam
Community Manager (Admin)
Update 3/20/25
Update 3/17/25:
Update 3/14/25:
Update 3/13/25:
Update 3/11/25:
Hi all,
Thank you.
Thank you for your patience.
GoogleNestTeam
16,162 REPLIES 16,162
It works , after I changed the time on my phone to 7 March
Hurry up
Thank you for providing the firmware update that downloaded just a few minutes ago. The “Chromecast Down” issue stands resolved. 👏🏼👏🏼👏🏼
Anonymous
Not applicable
Simple workaround- get an HDMI to usbc adaptor & plug into laptop/device then use your browser to stream shows. Simple until Google fix this! Good luck!
Thanks for the update info, I just found it.  Unfortunately I have rebooted the device but it has come up on my TV as "Get the app"
Download and open the Google Home app on your phone to begin setup
chromecast.com/,setup
Chromecast5365
I do hope you can help as we use it many times a day to play programs for my sick wife.  Any help would be appreciated.
Regards, Michael # 040321559
I have two Chromecast devices and one is working fine but the other is not. How come?
I’ve received the firmware update.
I am from Argentina.
since I did a factory reset, I first had recovered the Chromecast changing the date to a date before 8 March.
then today, the update just executed alone
and now I am able to cast again.
soy de Argentina. Recibí la actualización del software hoy .
en mi caso, como hice un reinicio de Fabrica, tuve que configurar el Chromecast con la fecha anterior al 8 de marzo..
luego esperé con el Chromecast conectado y la actualización se ejecuta sola.
Anonymous
Not applicable
How can you change the date if you did a factory reset like me and can't reconnect any more (because of the initial problem)? There's thousands of messages on this forum, so I'm unable to find the solution.
I’m very disappointed at this situation mainly because Google doesn’t give us a deadline to have the problem fixed. That’s terrible costumer service and it shows instability of the Company.
Both mine are back in action! Thank you 🙏
Tenho dois filhos pequenos e a única forma de assistir desenho em família e com o aparelho por favor resolver o mais rápido possível pois como não estava funcionando eu resetei o aparelho.
Não consigo acessar, infelizmente pensei que era um problema na minha internet e restaurei de fabrica.
Podrian decir cuales son los proximos diaa por favor? veo que hay usuarios que ya solucionaron el inconveniente yo todavia no pude y no lo resetee a fabrica. .. es todo muy poco claro
How can we know when you guys fix this problème
Can you let me know when you fix the factory reset problem?
Any news???
SBMB64
No. Still not working on my end
Ok.. waiting
Deveriam resolver isso o mais rápido !!!
Obrigado nos estamos esperando a solução do Chromecast que volte a funcionar
Tout  est rentré  dans  l'ordre 👏👏👏😊
Muchas gracias
Vanessa Dos Santos Chagas
Why is it taking so long?! Do you have a graduate in a broom cupboard working on the solution? Surely you must know the reputational damage this is causing!
I had reset mine, and we were able to reconnect it today.  Thank you very much for getting this worked out!
Não consigo usar o Chromecast, não encontra o Chromecast
Aún no tienen la solucion para la conexión de Chromecast 2da generación???
Thanks so much Google folks! All is running just as it was before, the fix works great!
Has a solution been found for those who performed a factory reset during initial troubleshooting? I still cannot re-setup my device.
I'm one of those who factory reset my 2nd Gen.....
Hoping for a fix ASAP.....
My chromecast is updated. Thanks to this community, I was able to restore the connection using old date. Thanks all for help!
Same here restored back from factory reset by backdating phone date to pre March 9th. Once connected and could see the Google pictures scroll through I was still unable to cast. Left Chromecast on and firmware update must have came through overnight. So all good now fully restored and casting.
I think google did it on purpose that we all will buy google tv stick. I bought amazon tv stick because it was 3 times cheaper than google. I thought my chromecast is broken🤦‍♂️ i wanted to buy new tv because i thought maybe he is broken because chromecast cant to connect to wifi. Its good that i didnt buy new tv🙄
Tentei configurar o dispositivo e não funciona é decepcionante não poder utilizar as funções de minha tv. Espero que resolva o mais breve possível 🙏🏻
Anonymous
Not applicable
Of course I did the factory reset since my Chromecast suddenly stopped working and I followed the steps for device problem solving that are advised by Google. Only on 13th of March in the evening I received an e-mail from Google to mention an issue and not to perform a factory reset. I hope Google will be able to fix this since the advisory step of a factory reset (only mentioned 3 days after my Chromecast stoped working to not to perform the factory reset at all even though it's advised as a problem solving solution) has let met to be blocked out and unable to receive the updates. If no solution is found then obviously all customers needs to receive a working new device.
Algo errado.
Any fix for the Chromecast Ultra? Mine stopped working a few days ago.
I tried restarting the modem, my phone, updating Google Home app and even did a factory reset on chromecast. Nothing helped. Here's the message I keep getting-
Could not communicate with your Chromecast.
This is ridiculous. I’m paying for streaming services and I can’t stream because your certificate expired WTF!
I already did factory reset. What should I do?
Has the fix been rolled out? Mine still won't connect
Do you have an ETA for the fix for those that performed a reset?
